86 E150 van with standard trans shifting stiffness...clutch or synchros?
Hi guys n gals,
my wonderful old work van has issues. Straight 6 and a 4 speed trans. Clutch pedal needs to be pushed all the way to the floor and the shifting is getting difficult. Reverse is either shut-off-engine-shift-into-reverse-start-again, or grind and jam.
Anyway to tell if my trans is going or it's just the clutch?
Hope one of you can help...
Thanks in advance!
Thanks in advance!
on
Hi guys n gals,
Thanks in advance!
Thanks in advance!
That's not how a manual transmission works. The cut of the gear teeth have nothing whatsoever to do with how it shifts. The gears are meshed at all times, no matter what gear the shifter is engaging, they're all meshed at all times, except for reverse. The syncros are engaged with a slider that moves to engage the blocker rings with the syncro teeth on the gears. The slider is locked to the main shaft (splined to it actually, the gears spin freely on the main shaft. The grinding you hear when a shift is missed is the syncro teeth and the blocker rings getting ground down by the slider. Helical cut gears run quieter, that's the only reason they're cut that way. And also the reason reverse is noisy, due to the straight cut gears.
It's got a hydraulic master cylinder and a slave cylinder inside the bellhousing, there's no adjustment there. When the clutch disc is worn out, it has to be replaced.
The slave cylinder should be out side the bellhousing on the manual transmissions unless it's a 5 speed or aftermarket.
I've never seen a slave cylinder inside a bellhousing , just hydraulic throwout bearings. Please tell me where you have seen this. I'm curious.
Now y'all are nitpicking. A hydraulic throwout bearing is a slave cylinder. You have a "master" cylinder and a "slave" cylinder which is the throwout bearing assembly. And yes, it is a doughnut shaped cylinder pushing on the throwout bearing that makes it operate. I know of no other hydraulic devices that are not cylindrical in shape. If there are some out there, please show us what they look like.
anyone who is a mechanic knows that
Pictures say it all
I have no need to debate you.
Actually the ones on the 5spds ( inside the bell housing ) are called a "concentric slave cylinder" . I've had the privilege of getting to replace a few of them.
Well, I AM a mechanic so I'll ask myself, "Do they do the same job" ? Yep, so while they may not "look" the same, they Do serve the same function, so in effect they are both "slave" cylinders. You have no need to debate me because you're wrong.
