4x4/2x4 Solenoid ground?
Hey fellas,
started diagnosing the 4x4 issue on my wifes truck.
Problem: wouldnt engage the front end and 4x4 light wouldnt come on.
So i thumbed around here, and googled issues. I watched ford tech makuluco's video on youtube and that got me started.
-So i changed out both of the solenoids for the 4x4 vacuum and 2x4 vacuum because there was no vacuum on top line in either 2wd or 4wd but there was vacuum coming to both from the reservoir.
-I now have 4x4 and the light, but the actuator still does not go back to
2wd position on its own. I had to push it out by hand.
-I then pulled the vacuum line off of the 2wd again and found that there is still no vacuum coming through the solenoid to pull the actuator back....
-I inserted a jumper wire then into the drivers side port of the connector
that attaches to the solenoid and put a volt meter on it. I held the
positive side of the meter to the battery + and connected the jumper
wire to the meters ground and I got a 12+ volt reading. Apparently
there is power... Sooooooooo.....
Does all of this mean that I just have a bad ground going to that solenoid? Are there any particular places that are prone to going bad or am I going to need to go on a scavenger hunt?
Thank you for any input and help.
Farmboypowerstroke
02-25-2015 06:53 PM
