What oil is everyone running - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Log In
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-19-2015, 08:26 AM
breedo99's Avatar
breedo99 breedo99 is offline
breedo99 is starting off with a positive reputation.
Was thinking about running Rotella but didnt know if there is a certain oil that these trucks like. Mines a 95 7.3 2wd crew cab dually with auto trans. Should i got conventional, blend, or synthetic? I know its usually a matter of personal opinion but just curious what everyone else is running. Also how much oil does my truck hold?
Old 05-19-2015, 08:45 AM
golfer.61 golfer.61 is offline
golfer.61 is starting off with a positive reputation.
I like rotella 15-40 conventional. It's the only thing I buy at wal-mart along with the Ford oil filter.
Old 05-19-2015, 09:03 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Schaeffers 7000, 14 quarts.
__________________
Glenn-3 PSD's
The 'Mule' 96 2WD F250 EC/LB auto PSD, semi-retired.
The 'Old Gray Mare' 97 dually cc, rest in peace. To be resurrected by a fellow FTEer!
The 'Babe the Blue Ox' 97 dually EC, all stock, for now!
Old 05-19-2015, 11:28 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE is gaining momentum as a positive member of FTE.MOOSE_MACHINE is gaining momentum as a positive member of FTE.
Delo 15-40 here.
__________________
Sometimes your the windshield, sometimes your the bug
1997 F-350 xlt cclb PSD 4x4 zf5, 160/80's, custom tunes, T500, DIY e-fuel, 6.0 i/c, 38R, 3" plenums, gauges, 4" turbo back exhaust, diy bellows, south bend clutch
1992 F-250 2wd eclb 5.8 farm truck
1989 F-350 4x4 7.3 c6 auto retiread
Nick
Old 05-19-2015, 12:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is online now
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Arrow
Motorcraft 15-40 here. 14 qtz
__________________
96 F250, E40D, 2WD, 3.55, 145K. DIY intake-exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; Tru-cool; CCV mod; 4" SS exhaust; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*;140IDM;6.0IC; cristal clear lenses; fuel tank mod; AC cold mod; coolant filter.
«Primum non nosere» Drive safely !
Old 05-19-2015, 01:36 PM
Buck Dharma Fan Buck Dharma Fan is offline
Buck Dharma Fan is starting off with a positive reputation.
Rotella T 15w 40. Motorcraft 1995 filter. Been good. 14 qts
__________________
1997 F250 PSD Ext Cab
Straight pipe/ no muffler
K & N FPRK Plumbing W/ 6637 Filter.
291,000 mi.
Old 05-19-2015, 02:46 PM
ved0303's Avatar
ved0303 ved0303 is offline
ved0303 is starting off with a positive reputation.
I always use Schaeffer 7000. Really nice stuff but a bit hard to find and expensive.
Old 05-19-2015, 05:08 PM
$20 a gallon is inline with Rotella syn.
__________________
Glenn-3 PSD's
Old 05-19-2015, 05:11 PM
David7.3's Avatar
David7.3 David7.3 is offline
NON COMPUS MENTIS
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
I use Rotella 15w-40 and because i'm getting up there 260,000 I add 2 bottles of STP oil treatment. Still rolling coal when ever I want.
__________________
1999 F-350 PSD, 6 inch all spring, 35" Toyo load E tires, 140 gallons of fuel, Detroit true trac front, Detroit locker rear, BDS trans, banks billet converter, banks trans command, TS chip, banks turbo housing, wicked wheel II, FRx Kit w/black spring, Non-EBV Pedestal, diesel site coolant filter, 203 t-stat, IAH delete, 4" turbo back exhaust, 6.0 trans cooler, Riff-Raff wastegate, 1994 Ford f-350 ambulance, 7.3 IDI 40,000 miles, rear air suspension, full light bars, strobes, sirens ect. for sale
Old 05-19-2015, 05:30 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a very good reputation on FTE.fordman67 has a very good reputation on FTE.fordman67 has a very good reputation on FTE.fordman67 has a very good reputation on FTE.
Valvoline super blue 15w40 conventional.
What can I say...gotta b different lol
Old 05-19-2015, 05:42 PM
Quote:
Originally Posted by fordman67 View Post
Valvoline super blue 15w40 conventional. What can I say...gotta b different lol
we've noticed
__________________
Nick
Old 05-19-2015, 06:00 PM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr is gaining momentum as a positive member of FTE.LeoJr is gaining momentum as a positive member of FTE.
Quote:
Ditto.
I punch a hole in the bottom of the filter to drain it. Pre-fill (takes a little time for it to sift through the filter) before installing. And write the date and miles on it with a sharpie.
__________________
*1996 F250 crew cab/short bed, 4x4, auto PSD*stainless window vents *remote door locks work with engine running mod.
Link to my D60 refurb and OBS swap thread Link to my OBS air vent R&R thread Link to my grab handle install
Link to my tire size comparison pics
Old 05-20-2015, 05:52 AM
majorgator majorgator is offline
majorgator is starting off with a positive reputation.
Been using Schaeffers Supreme 7000 15W-40 (14-15 quarts, depending on how I feel that day) and the Motorcraft FL 1995 filter. Very pleased with the Schaeffers. Runs smoother, quieter, and seems to maintain viscosity better over the 5000 mile interval. I buy it on Amazon, and a complete oil change costs right at $100.
Was running Mystik Super HD but the oil sample results were consistently showing lower viscosity about half way through the change interval.
__________________
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes), Bushwacker Street Flares, Riff Raff Bellowed Up Pipes, Billet Alum Compressor Wheel, EBPV Delete
Old 05-20-2015, 09:34 AM
Bearhugger1933 Bearhugger1933 is offline
Bearhugger1933 is starting off with a positive reputation.
Rotella 15w40 338000 no problem
Old 05-20-2015, 10:34 AM
ved0303's Avatar
Thats nice to know you can buy Schaeffers on amazon. I have been getting it at the local Napa but they never have it in stock so I have to buy a gallon every time they have it until I have enough
__________________
Vince
1997 F250 Powerstroke- Rosewood Stage 2s, T-500 HPOP, E-Fuel conversion, S366, 6.0 Intercooler, 4 in exhaust, 6637 intake, Hydra chip with Gearhead tunes, Dana 60 with PMF RSK.
1975 F250 Highboy- upgraded 360FE, still slow.
Similar Threads
type of engine oil effect EOT? jlatr 6.0L Power Stroke Diesel 9 03-23-2015 08:02 PM
oil derek4343 2009 - 2014 F150 21 02-25-2014 12:47 PM
oil ken1960 6.7L Power Stroke Diesel 27 12-06-2013 01:12 PM
What oil for the 6.0 Green96 6.0L Power Stroke Diesel 28 09-02-2013 10:54 AM
What gear oil for true-trac 96grimreaper Excursion - King of SUVs 7 08-25-2012 10:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
