base where distributor sits on is broken?
on
I just replased new distributor had bad ignition module, ran great died today got it home thought it was timing chain, pulled valve cover, valves moved ok. distributor is rotating,when I pulled distributor, gear at bottom had metal shavings, looked down hole the base where it sits was broken almost in half. Dont know if that part is on block or cam. this is all the way at very bottom of distributor
have 1986 f150 xlt cajun cruiser 302 fi, what i thought were metal shavings when put in fingers and rubed it broke up, like hard gunk, the old distributor had a chip on dizzy gear in one spot about 1/4 inch, cam gear looked ok maybe a little worn looking kinda hard to tell, think maybe best to check timing chain and gear? thank God have 1983 f150 for backup till then
I've changed two timing sets recently, both of them the plastic coated variety, but those cam sprockets were in much better shape than his. Is it common for the sprocket to be that chewed up? Looks like it's pretty excessive wear!
Then again, it doesn't really look like that motor has been taken care of either.
[IMG]http:/80-/cimg5.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/1600x1200/0614151332_00_ba0fc2bf72c9f7a6d2697965bd3d6e12902d 1901.jpg[/IMG]
just removed timing chain, sure looked jumped, has 2 broken teeth, could almost take chain off as it sat, will replace with new set, also drop oil pan and clean out. Any other advice depreciated.
i was given this truck about one year ago, it was sitting for about 5 or so years, the previous owner was brick layer he hauled every thing with it sand, brick etc. i put about 800.00 or so into it to get it on road, ran it for about 1 yr. takes 1 quart every week, can"t sink much more money into it, would love to overhaul it, maybe if things get better, just can"t right now, i just love these old ford trucks, know what i mean
#29
I have done a couple. Even though the engine is wore out, you wil be surprised how much better it starts and runs once you get the new chain in place.
I have nursed some pretty bad engines along in my years. If you find you get a bunch of oil going into the air cleaner and pretty much all over because of the blow by, take a old piece of garden hose or heater hose and hook it to the valve cover fitting(the one opposite the PCV valve) and run it down over to the frame and let it dump into a old coffee can. That will let some of the pressure out of the engine and keep all that mess out of the carb.
#30
