5R110 Transmission Fluid Change?
Hi guys, new member here. Truck is an 05 F250 6.0 (originally) but recently converted over to a cummins ... I know, I know sorry Ford guys.
Anyway, my brother did all of the work on the swap and he went with some wolfs head transmission fluid or something like that. I want to switch it back to the correct fluid which I believe would be the Ford Mercon LV?
Is this a simple warm the truck up until shes warm, drain the oil and drop the new fluid in?
I'm only asking because the last thing I want is to destroy this transmission. If you're wondering, I used the PCS transmission controller to tune the transmission. I think it will shift smoother once I change the fluid back to Ford.
Thanks!
Thanks!
roostercrows
05-10-2013 11:10 AM
fairview1
12-31-2012 10:53 PM
