Yet another headers question
You would be better off trying Hedman or JBA.
The Flotech headers I helped install on a '95, 4wd needed modification due to the starter. Torch to bend and dimple. Also, be sure you get the ones that have an O2 sensor bung installed.
You can get an O2 sensor bung welded in, but that costs too. In any case, I would AVOID Flotechs. Spend the extra and not have to worry about heat and bend and dimpling and welding an O2 bung in. Also, a few of the header bolt holes wouldn't line up quite right and needed to be drilled, dremeled a bit so they could be bolted on.
I'm sure others will chime in with wisdom, so maybe they can agree or disagree with my statement and offer better ideas.
i didn't need to modify my flowtechs to clear the starter (manual trans), but I needed to bend the drivers side to fit around the front driveshaft.
you should be fine with 2wd with the flowtechs, but they are junky in the grand scheme of things. mine have been on for over 5 years now, if I knew how well the pacesetters fit back then I would have just gotten them in the first place. when mine rot out (its imminent) ill be getting pacesetters.
harley
04-16-2002 05:53 AM
