trans back after clutch job
Can someone PLEASE give me some hints for how to get the trans and xfer case back in after I replace my clutch?? It took us almost 8 hours to get it out. It was jammed up between the exhaust and the tunnel so bad we ended popping the bell housing loose and the whole thing fell out on the ground!!
Can you install the bell housing first then the trans?? Is it hard to take the case off first then put it back on after the clutch??
Any sugestions are MORE than welcome
Chris
Chris
on
I can't see why you would have trouble getting things apart. On my '78 f150 4x4 there was plenty of room to remove and install the 4 Speed Manual. I can't think of why you couldn't mount the bellhousing first and then poke the transmission in.
If the exhaust is in the way, drop it by removing it from the engine. There should be enough play in the exhaust to allow it to fall away, hopefully enough to install your transmission.
Also, When I did mine, I dropped the rear of my 300 to make the mating easier and clear stuff. Then Huffed and Puffed and stuffed the NP205 T-Case on with it on my belly then up in place. Fun times doing this without the right tools
Make sure the Clutch is aligned before torquing the pressure plate to the flywheel.
CB41105
01-20-2019 05:51 AM
E30tdf
12-30-2006 11:04 AM
