fuse for dash lights (97 f150) blown? - Ford Truck Enthusiasts Forums
Old 07-28-2003, 03:51 PM
billa billa is offline
billa is starting off with a positive reputation.
My dash and radio lights are out.
Initial look at fuses shows they are all good.
Am I looking at the right fuses (in the Power Distirubution Box)? A relay? What size, location would this fuse be?
What is the small fuse box containing a single row of about 6-8 fuses right behind main fuse box? I fumbled it's cover down into the body while looking for the bad dash light fuse?
Thanks in advance
Bill
Old 07-28-2003, 07:13 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Instrument illumination is fuse 18 in the interior fuse panel. The cover has the locations numbered. It will be a 5 amp fuse.
Old 07-28-2003, 08:11 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Did someone turn the dash light dimmer all the way down?
Old 07-28-2003, 08:13 PM
Nope.
Old 07-28-2003, 08:14 PM
Naw that never happens.. Like the many who have their cars towed in because the battery ran down and I found the dome lamp switch locked on. :O
Old 07-28-2003, 08:35 PM
I have a 30 amp fuse in location#18.
I've got a 5 amp fuse in spot #1, but it is fine. Except I just dropped it into an unreachable spot below the fuse box---dooh!)
97 f150.
Old 07-28-2003, 08:39 PM
Fuse 18 in the power distribution box or the interior fuse panel?
Old 07-28-2003, 08:46 PM
#18 in the PDB. Where is the interior fuse panel?
Old 07-28-2003, 08:48 PM
Left side of dash, a pull out panel, and the cover pulls off with fuses under it. Cover is numbered.
Old 07-29-2003, 09:00 AM
I found the interior fuse panel. My cover does not have the numbered locations listed on it.
Funny thing, this morning the dash lights work again! (I never actually verfied the 5amp fuse in #18 interior panel was good).
What does the small (6 slot) fuse panel behind the PDB serve? That's where I dropped the 5amp fuse from slot #1.
Thanks.
P.S.
Is there a website where I can see information about fuse locations and what they serve?
Old 07-29-2003, 11:04 PM
now they don't work again.
is it a 5amp in #18?
I'm missing the location guide (not on panel cover) -anyone help with orientation on the panel?
Thanks!
Bill
Old 07-30-2003, 09:15 AM
this morning they work?!?! Hmmm....
Old 07-31-2003, 10:46 AM
and they work again this morning. begining to think bad switch...
No Dash Lights, No Power to Fuse Box? (Tail Lights OK) DesertZuki 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-16-2015 12:03 AM
What Size Fuse? swampthang 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-15-2014 08:57 AM
What number fuse are the trailer tail lights? bar20 2004 - 2008 F150 4 07-13-2010 09:48 AM
1990 f-150 4x4 fuse diagram oldgreenf100 1987 - 1996 F150 & Larger F-Series Trucks 2 01-21-2007 09:56 PM
What fuses under dash of 72 F-100? soco 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-26-2006 07:52 PM
Tags
97, dash, f150, fuse, light, lights, located
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
