EGT Sensor #3, how in the heck...
Since I got the Check Engine light today and the ScanGaugeII shows it to be the EGT Sensor #3. I'll take it to the shop tomorrow and let warranty cover it.
But, this evening I though I would crawl under the truck and just make sure nothing came unplugged or a wife pulled loose. I keep two extra sensors in a emergency tool kit for one of those worry times of the sensor going south while on the road.
My question is how to you get to that sucker? I couldn't figure out a reasonable way to get a wrench on it with room to move. Least of all bend my arms in such a way that a contortionist would be proud to do.
What am I missing, is there a secret someone would care to share
Unless you have taken pre-emptive measures of removing and reinstalling with anti siege grease, you will most likely need a torch to remove them on the side of the road.
Having two in my parts kit saved me a week+ waiting for nationwide back order. And thanks to this forum, I knew what it was when it happened to me on the middle of nowhere and let it cool down so I could limp into a dealer.
Hope the mpg robbing (for some but not all) re-flash puts an end to the sensor failures.
Less than a 1/2 for me on the flash. I barely had time to sit down and check my phone for messages.
on
I got 3 of the 4 EGT sensors out of my truck to hit them with anti-seize. Number 3 seems to be frozen in place and my flare nut wrench (Mac tools) is just splaying when trying to get it out. This was when my truck has less than 1,500 miles on it... I will be trying again with the truck up to temp, but working around the exhaust when it is hot is not my most favorite job...
