cold blooded
Received 3,100 Likes
on
yes it is a power stroke, a july build date.found that out the hard way every time i order a part i have to tell them its a 1995. is there a way to test the glow plugs on the truck. o ya when i first got it i found the left bank pigtail was fried napa had a kit valve cover with new pigtail and i replaced the four glow plugs on that bank.
on
what type glow plugs did you put in? if anything other than motorcraft ZD-11's, i bet they are burned out already. the autolite glow plugs are the absolute worst garbage made and sold, i have seem many burn out after one start. and the champions and a very close second on the garbage scale.
first thing i would do is check for voltage on the output side of the glow plug relay at key on on a cold engine.
if you have voltage, than i would say dead glow plugs.
on
i have been getting my glow plugs from rock auto for quite a while now.
they have the ZD-11's for $9.13 each : More Information for MOTORCRAFT ZD11
on
norm805
02-03-2019 06:45 AM
wizofnet
02-17-2014 07:59 PM
Flying Finn
18
10-29-2009 01:34 PM
wgw
02-18-2005 06:00 PM
