What on top of my fuel tank?
I found this 1994 Ford F-350 Fuel Vapor Valve | FordParts.com on Ford parts, but it looks like I need part 9B593. This is the assembly and I want to try just the top. LMC Truck has what they are calling a "Vent Valve-1 Port" part# 40-1955. Truck Parts and Truck Accessories I realy dont want to spend another $150 on this tank. Let me see if I can take it off without braking it.
I just found this Diagram. No part numbers but now I know how it should be hooked up.
Fuel Vapor Valve
Fund this.
Item Part Number Description
1 9002 Fuel Tank, Midship
2 9C987 Valve Assembly, Evaporative - 4.9L and 5.0L Engines
3 9B227 Hose and Valve Assembly, Evaporative - 5.8L and 7.5L Engines
4 9S278 Tube Assembly, Rear Fuel Line
5 9104 Fuel Tank, Aft-of-Axle
6 9J338 Tube Assembly, Front Fuel Line
7 9D319 Bracket, Fuel Line Support
8 N805526-S190 Connector, Fuel Line Supply
9 N805528-S190 Connector, Fuel Line Return
10 9F274 Clip Assembly, Fuel Line
11 9C016 Tube and Hose Assembly, Vapor Return
12 9A335 Bracket Assembly, Fuel Filter
13 370443-S32 Clip
14 N620480-S2 Nut
15 9D653 Fuel Vapor Canister
16 N620480-S2 Nut
A - Tighten to 8-10 Nm
(71-89 Lb-In)
B - Valve Must Be Installed As Shown
Fuel Vapor Valve
Fund this.
13 370443-S32 Clip
14 N620480-S2 Nut
16 N620480-S2 Nut
(71-89 Lb-In)
Sorry for all the posting but I'm hoping this well help other like me. Found another form page talking about this with pics.
https://www.ford-trucks.com/forums/8...i-do-this.html
on
You cant seal it off it has to vent, for the expansion on a hot day, and when your at the pump she might shut off on ya. I bet ya I have one at work, used but it will look a lot better than that, do you want me to take it out, you can PM me your address and I will ship it out tomorrow. your call
OK so the Dorman is no good. Its to small. I found an OEM replacement from broncograveyard part #30260 for $110. Bronco Gas Tank Roll Over/Breather Valve-Broncograveyard.com But they sell an alternative for $16. You will need part# 30259 and #30259S. 1980-96 Bronco Gas Tank Breather Valve-Broncograveyard.com 1980-96 Bronco Gas Tank Breather Valve Seal-Broncograveyard.com When I get them in I will let you know how its go's.
blue76
07-02-2016 06:16 PM
lolbowties
04-13-2011 09:31 PM
