How to decide ... Vent window or 1 piece?!
I have a '56...it's a patina truck. Driver window is shattered, and it bugs me and I want to put glass in it. It's not on the road yet and won't be for a while, but I'm not painting it.
I'm at the supernationals right now and I just can't decide on which I like better. I love the look of 1 piece, but would it look out of place on my truck?
Any help or opinions appreciated!
True, that's why I'm torn. I have the vent windows on my '65, and rarely use them because they don't stay open...but when I hold them open, they move some air!
My 56 and my 49 both have working vent windows that stay open, even at road speed.
I drove the 49 from south of Knoxville to the Supernationals at I40 road speed yesterday, Thursday. Quite glad I had the vents. Might want to replace the seals on your 65 as they do work when right. I am sure the girls at Mid Fifty will fix you up with seals for the 56 and DC will have them for the 65. BTW, spend a few extra$$ and get the hollow seals for the 56. I installed some off brand seals that were with the truck when I bought my 56 and they are too stiff for the doors to close right. DC or Midfifty regular seals will probably be ok. Seals on my 49 are a DC product.
Take your inspection panels off and tighten the nut on the bottom of the swivel inside the door just a little (a small ratchet with an extension works well). It will probably tighten up the mechanism so that they don't spin around on you.
An old trick in the summer back when all cars had vent windows, and most didn't have AC: Turn the vent windows all the way out so they reverse direction. Now they will act like scoops bringing in a lot of air. This works even if the main windows are down. To get ventilation without getting soaked in a summer rain, open the cowl vent 1/2 way and open the vent windows about an inch.
Thanks for all of the great replies guys. I won't have ac anytime soon, so I guess it should be obvious...
These are a couple of the "pros" that have me considering 1 piece:
- simple install without as many pieces to try to fit together (ie: the rubber and and felt never seem to look right on most trucks and definitely don't seem to be real snug) But also, I guess there are some irreversible modifications to make to the door for the 1 piece to work?
- aesthetically pleasing / simple look (although not original) I think it really looks nice on some trucks
- At least one owner with 1 piece at the show told me that it cut down on wind noise.
luckily, I didn't have to decide at the show today. Either way, nobody had the glass I wanted (clear) in either 1 piece or regular...
I guess I'll just do like most things for my build...think about it for 6 months - 1 year...just to do what I had decided 1 year earlier.
Aesthetically I like the one-piece window...I have them in my trucks and my 40 Ford coupe. That said, if your only gripe with your current setup is the fact that the vent does not stay open then just fix them. If you are going to be into the door anyway replacing the side glass, go ahead and pull out the vent window assy and replace the spring. Your truck would look much better with the stock setup...
Received 4,132 Likes
on
Awesome, thanks again for all of the replies.
I have decided to keep the vent windows (was always my plan...but had a lapse in judgement today apparently...).
The reason I'm even talking about it is because the driver door glass is shattered. Can someone confirm that I can take my passenger side glass and have two pieces cut exactly like it to get new side windows for driver and passenger side? I was going to buy a whole kit at the show, but he didn't have clear, only smoke.
