53 chop top
Old 05-15-2015, 08:48 AM
classicrat52's Avatar
classicrat52
classicrat52 is offline
53 chop top
I'm really interested in chopping my 52 f3 wondering if anyone has done a 52 before, I'm wondering where to pull my measurements from and what will I need to do the chop? I've done lots of reading but do I actually need a extra cab to make the roof fit and the doors, I've seen guys use parts of the pilar for the door but any advise and pictures would be great thanks
Old 05-15-2015, 10:25 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,449 Likes on 1,396 Posts
Most guys who chop tops correctly find having an extra roof section from a donor cab helpful in fitting the parts back together. As you lower the top, the top area becomes larger, both front/back and sideways, and you need to be able to use pieces from the donor to section in the gaps. Alternatively, you could "pinch" the posts together to take up the space, but that creates odd and unattractive aesthetics, and makes the doors a lot harder to fit. Speaking of doors, you'll have the same issues in the window areas, as well, and donor doors are helpful, too.
Top chopping is an advanced fabrication project. If you don't have good fab skills, I would suggest seeking out local, professional advice. It's the kind of project that can go horribly wrong, very quickly, and turn into a big pile of scrap if you're not careful.
Best of luck with your project.
Old 05-15-2015, 10:35 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
This is an ambitious undertaking and from the nature of your questions I would have to assume that you do not have a lot of experience in this area. My suggestion to you is to find a copy of Ron Covell's excellent DVD video on "Chopping and Sectioning". In this video you will learn from the master all that you need to do to complete this job properly. Good luck...
Old 05-15-2015, 08:00 PM
firstrider's Avatar
firstrider
firstrider is offline
Have seen chopped 51 & 52 trucks & IMHO they just do not look proportionate .They look like a Studebaker & an F1 mated & the outcome was an abortion .
Old 05-15-2015, 09:04 PM
auto doug's Avatar
auto doug
auto doug is offline
I to am a bit skeptic on chopping a 52, I do chop tops often but it has to be done very carefully or it will look.... wrong! some trucks don't need it, others do like the late 40's I-H trucks they all need chopped & redesigned! But I did mine in a reverse fashion, I'm a long time body metal man and a re designer of a lot of things, note the chopped fox body mustang, So I studied this I-H truck and decided it needed a reverse pancake slant chop! of 4 inches (ever hear of that? well that's what i did) and the look was outstanding! along with extending the cab 2 inches, basically flattened the top of the cab roof line and pushed the back of the cab rearward this made the windshield post slant rearward as well giving a more stream lined look! A lot of geometry going on here that you don't even think of so be ready for some head scratching, stuff they did cover in school!
I did this as a weekend workshop and the guys all had a great time learned a lot and got in some good practice time with some cutting & welding. Also We pancaking the hood 3 inches, nipped and tucked the frt fenders 3 inches per- side, expanded the rear window opening 18 inches also helped, the new look is just what the old truck needed.
So what I'm saying is metal cutting and moving lines around just a little can greatly change the look you just gotta make sure it's what you want and can do! I alway try this first with pictures and a razor blade (7th grade art class stuff) if I can get it to look good in a chopped up modified picture I can do it in metal! I have this I-H project on DVD that might help you with your thoughts?
let me know,
Doug
Old 05-16-2015, 12:36 PM
48 Steel's Avatar
48 Steel
48 Steel is offline
Here is a link to my build. In it you will see how I chopped my 48 F1.
https://www.ford-trucks.com/forums/1...lt-thread.html
_____________________________________
1948 Ford F1 - Darkside
1946 Ford Tudor - Lightly toasted
Old 05-16-2015, 12:56 PM
00Boss's Avatar
00Boss
00Boss is offline
Auto Doug, I thought when you said late 40s you meant L-series. I'm glad you included pics to help clarify. I have yet to see an L/R/S-series with a chop and am now curious as to weather it would be a good look or not. That KB is a great looking chop too.
I have no experience with chopping, so I can't help explain anything. But I do agree the 48-52 cabs are best left as is.
Old 05-17-2015, 10:16 AM
classicrat52
Thanks 48 Steele, wicked job, that gave me just what I needed, did you have to widen your roof?
Old 05-17-2015, 10:33 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
No, In one of the pictures I did change out my old roof due to my original having some bad dents. I have friends that have done chops on the F1's and the amount you take out will determine if you have to add or subtract roof material.
Thanks for the comment
Old 05-17-2015, 12:26 PM
classicrat52
So at 2" I don't have to add anything? And did you have any troubles getting your glass to fit moving for front pillars?
Old 05-17-2015, 05:46 PM
48 Steel's Avatar
48 Steel
48 Steel is offline
No problems at all. I also removed the wing windows so when I got ready for glass I made patterns for all 3 windows and had them cut.
Rusty B
15
11-16-2017 08:29 PM
Bullmoose C
10-30-2014 10:51 AM
fordCOE
15
11-01-2011 10:02 PM
rtcalabrojr
13
03-16-2008 08:18 PM
bsteele52
18
05-17-2007 10:21 AM
Quick Reply: 53 chop top
