Are blower motors compatible between different makes?
Old 05-14-2015, 02:31 PM
purpleaustin's Avatar
purpleaustin
purpleaustin is offline
For example, I have a blower motor in my dead ford explorer that I want to take out and get a mechanic to put into my chevy astro van. Is this possible? I'm about to take the explorer for scrap because the transmission died. Any advice will be appreciated.
Old 05-18-2015, 08:00 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
Blower motors can be had for less than $60 brand new---not sure paying someone to install a used part is all that financially wise.
Old 05-19-2015, 11:19 AM
purpleaustin
Ok, i just read my manual and rslized its pretty easy stuff. So anyways, is a blower motor from a ford going to be compatible with a chev?
Old 05-20-2015, 07:04 AM
JWA's Avatar
JWA
JWA is offline
Probably not---just buy the part that's designed to fit the application.
Old 05-28-2015, 11:28 AM
mikeinri's Avatar
mikeinri
mikeinri is offline
Maybe, but not likely. One way to check would be to look up aftermarket part numbers for both vehicles and see if they match.
For something like this, it could be a simple change like the electrical connector. You could look for some OEM detailed specs (size, speed, bolt hole layout), but those might be hard to find.
Hope this helps.
Mike
Old 05-28-2015, 11:39 AM
purpleaustin
thx for the tips
GlenPxC
1999 to 2016 Super Duty
06-05-2019 08:43 PM
wpannone
05-09-2016 09:56 PM
dhuddleson
03-10-2016 04:19 PM
fordboy67
15
01-18-2013 06:59 PM
meier63
26
04-11-2011 08:17 AM
Quick Reply: Are blower motors compatible between different makes?
