Stroker Time!!!!
Stroker Time!!!!
90 f150 4x4 302 manuel 5spd. Im getting rid of the old 302 and buying a 408w short block from summit for 3,300 the one with the full forged rotator. Going to run a set of 185 AFRs with 58cc combustion chamber, believe the pistons are -5cc dish. RPM air gap dual plane intake with holley 750dp and a comp 35-426-8 cam with retrofitted hyd roller rockers. MSD distributor vacuum advance with 6al box and taylor wires open long tube headers. Since the truck was originally efi I'm going to use the stock pumps with a regulator with a return line because the truck did have a fuel return line from the factory. Correct me if this won't work? I will have to hook up a new throttle linkage but i believe all the gauges ran straight to the dash not computer so they should still work? Any obvious problems I have overlooked? Looking for 500+ hp at the crank.
If I was going to shoot for over 1hp per cubic inch do you have any tips to help me get there?
Something bigger than AFR185s and a custom cam. Budget for some real headers. It's going to take some money to make big numbers on all motor.
This site used to have a bunch of active dialog: SBFTECH.com Experienced Small Block Ford Tech - Index
But it has died down quite a bit since Cam-Master Jay got too big for his britches and was banned. Tons of good info there, especially the Myths forum that becomes visible once you join and have about 20 posts. It's an eye-opener that debunks common held beliefs of what is "supposed" to work.
I was always under the impression, that with the regulator on stock pumps running a carb, we'd be fine stretching it out. Maybe I need to look more into the whole volume vs pressure thing. Changing pumps in a truck is easy enough though.
