Got a blast cabinet?
So, I need/want one. Looking at tp tools 966 pro finisher. Quite a bit of price difference for the extra 6" in height. 960 is 400 less and free shipping(total 600 less).
Any solid reasons to be happy with the smaller one?
Got any input on size requirements for restoring the best trucks in the world.
The bigger the better believe me. It's not the size of the parts that's the pain. It's when you have to keep flipping them different directions to get it all that's the issue.
Also search blasting cabinet water trap. I built mine out of 5 gallon buckets and pvc fittings. Worth every penny to reduce the dust inside and out of the cabinet.
you can also buy the smaller one plus an out door canister one, ive had mine over 30yrs and still get's used. I have the harbor frieht cabnet one and it works just fine, we've done heads,intakes about everyone i know comes over and use's it. I also have one of the small hand held ones for small quick jobs down outside.
This is the 48" wide cabinet I have (only in red).
960-T Pro Trig-Blast Sandblasting Cabinet - TP Tools & Equipment
I took a small 15 gallon barrel (same size as the vacuum unit in the photo) and use it as an extention on the left side of my cabinet. If I need the added length to blast something long, like a rear end housing, I can attach the drum to the side of the cabinet. If I don't need the extension, I can cap the hole off.
You guys crack me up!
I was thinking about putting the vac upstairs in the barn and vent it outside. Keep things somewhat quiet.
This is one of the last major tools I currently think I need in my shop....I can fab up a ext pretty quick going sideways but raising the roof would be slightly more complicated. Plus I'd probably be too lazy to fab it,,, if it didnt fit I would just use the outdoor blaster which I hate dragging out.
ultraranger.....are you happy with that vac system?
No comment on size but bigger is always better. Can say that TP tools is only an hour from my house and I have been there many times. Those cabinets are all built in Canfield Ohio and they are nice quality. Have used one before, and like I said been in the factory. It is a nice place to visit if ever in the area.
Yes.
I've used my blast cabinet a LOT in the 9 years I've had it. Two things I wish were different on the model I have (I just haven't changed them); I wish there was also a light on the right side and, I wish it had a foot pedal instead of a trigger nozzle.
I use Skat Blast media. It's a little more aggressive than glass beads because it's finely crushed automotive glass. It strips parts quickly.
Air Supply: I bought my compressor on Christmas Eve, 2006 in preperation for buying a bead blast cabinet (which I bought four months later in April, 2007). I knew a blast cabinet would be the most demanding tool (air consumption-wise) on the compressor, of any tool I have.
Unlike other peoples blast cabinets I have used, I didn't want to continually have to stop blasting to wait for the compressor to catch back up, before I could continue on. I bought this compressor at Home Depot.
I NEVER have to stop and wait for this compressor to catch up, because it doesn't get behind (23 SCFM @90 PSI, 7.5 hp motor, 80-gal tank, two-stage, 175 PSI max output).
ultraranger....Thanks for the info..I" have a Quincy 23 cfm coupled to another 40 gallon tank. Air is not a problem.
Pretty sure they both come with the foot pedal but I'll doublecheck.
How often do you replace the inner lens covers? I guess I should say how many do you purchase at a time?
I buy the lens packs from TP Tools but don't remember the specific number of lenses that come in them.
I would also suggest getting one of their sifter/strainers to sift out large debris from the blast media.
