1966 f100 to f350 coversion
i have f350 axels out of a 1978 f350 custom and I want to put them under my 1966 f100 but the front leaf springs are 6" longer than the front of the frame to the front of the cab. I know the f100 is coil front suspension and im going to have to convert it to leaf front but I also want it lifted 4 inches in the front because I have 4" lift blocks for the back. what should I do to make them fit? Please help.
My 66 is 2wd and I have the frame, running gear, tranny, transfercase, cab with steering colom and steering box, and the drivelines of the 78
and then my 66 is complete but I want it to be 4wd and lifted
and yes the leafsprings from the 78 would be sticking 6" under the cab on my 66 but the 78 used to be a homemade towtruck that my neighbors had and so they put 4" lift blocks under the rear to compensate for the weight so that it would be evened out but they never lifted the fron and so I was wondering if it would work just to arch the front leafs 4" and then squeeze them a little bit to get them to fit under the front of my 66.
Okay, good that you have the entire thing.. There are shops that can arc the spring more so they will fit for you and possibly get a little lift. You won't be able to bend them into place yourself safely..
I'm assuming you're going to use the spring hangers off the 78?
Are you swapping the motor, transmission and transfer case as well? This will be a MAJOR undertaking is why I suggest swapping bodies if the 78's frame is structurally sound(The cab IS a direct swap)
Okay well this is what you will need
Modified motor mounts
Modified transmission mount
You will have to cut a hole in the cab for the stick
Modify your 2wd front crossmember
Customize track arm bar for front axle
Remove all old suspension and front coil buckets
Add new/custom leaf hangers
New leaf springs to fit(I'm honestly not sure why they need to be shortened)
Relengthened drive shafts
Clutch rod lengthened
Transfer case shifter lengthened
New radiator
New brake lines(plumb proportioning valve)
New bracket for brake booster
New brake pedal linkage to fit new brake booster
New steering box
Modify frame for box
80's Ford steering column with adjustable linkage
Bracket for steering column
And lots of miscellaneous stuff I'm not mentioning
This is my build and shows what is involved with swapping the body
https://www.ford-trucks.com/forums/1...4x4-frame.html
New radiator
New steering box
Also, I wouldn't put any lift in the front of the truck until I had the thing sitting on the axles. A lot of the older trucks used lift blocks under the rear axle to compensate for the extra height of the front axle setup over a 2WD setup.
I helped a guy lift an old Blazer years ago and we had to take the factory blocks out of the back and replace them with taller ones that came in the kit.
Your truck might sit level with the straight axle setup in the front and the blocks in the back.
I really don't want to unbolt the cab, bed, engine, and front wrap on my 66 though and I don't know if the 78 frame I have is a long or short bed
No such thing as a 1978 F350 with 4WD unless it's an aftermarket conversion / 1979 was the first year that Ford offered the F350 with 4WD
1965/79 F100/250 2WD - 1966/76 F100 4WD - 1967/78 F350 - 1975/79 F150 4WD (except 1977/79 Super Cab) - 1979 F350 2WD have coil spring front suspension.
1978/79 F250 4WD & 1979 F350 4WD have a 2 leaf front spring pack.
