Truck grinds out of Neutral at traffic lights
#31
#32
Sadly this is in-town Atlanta so there are some lights at big intersection that can last between a minute and a half and two minutes. While I can hold the clutch that I was always taught I was wearing it out by doing this. I think this truck might be more at home on county roads in rural GA.
#33
I am from Atlanta too and so I think we can actually run 140 here year round no problem, especially if you keep it in a heated garage as I do. I think I had 140 in my transmission originally but I was unsure of age so I changed it back in March after I gathered input from folks here on correct weight. I went with sta lube 90 weight and had same issues talked about here, grinding at red lights and grinding from 1st to 2nd. Changed to 140 and no issues, it is sta lube as well I picked up at O'reily's, spend the 5 bucks and get the push pump, no mess!
#34
Good to find another Atlanta on the board. I have been thinking about a pump of some sort. I have been using quart squirt bottles but they are a bit of a pain. I'll try to find the StaLube this weekend. Just out of curiosity at which O'Reilys did you find it?
Thanks,
John
#35
O'Reily's in Canton, which is about 50 miles north of downtown. Find the closest one to you and call them and they will order it for you, if they don't have on the shelf. It comes in gallon jugs I think. I work in Atlanta but live in the mountains so my F1 still gets to see the country roads. You will have to come to our next cruise-in in Canton, they put on a great show.
#36
#38
#39
Dang, I just moved from Roswell to Tybee about a month ago, who knew there were so many old trucks in Atlanta.
I still get to the ATL fairly often and will try and stop by one of the meets.
Back to the topic at hand, with the heavier oil, do you have any issues with double clutching on the down shift? (when you need the shaft to keep spinning)
#40
#41
#43
I did notice better shifts when the system was cold with the 85W-140 but it would get progressively worse as it heated up. I have not yet driven with the straight 140W but I am hoping for the best. I will try driving it to work tomorrow.
#44
Well I can say it is improved but when the transmission oil gets hot (30 minutes of driving) the issue persists. Also I notice I grind more on my 2->3 shifts when it is cold. I guess I am at a happy medium?
#45
