1955 Ford F250 Custom Camper w/1964 390 Police Interceptor
Old 05-18-2015, 07:47 AM
mokandshuk's Avatar
mokandshuk
mokandshuk is offline
My priority is to help identify solutions, not to sell a set of my wheels. <------ I know, from what I have read online though tubeless tires/rims are better than tubed versions. But if those 20 inchers will def work than it would be nice to have something almost exact on there to what was on there.
  #47
Old 05-18-2015, 07:57 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Originally Posted by mokandshuk
I will be crawling under it today to determine the exact type of rear end. My uncle told me he thinks it is a 2 speed rear end, but I will hopefully know the exact make/model by the end of the day. .
A closer look at one of the pictures you posted does indicate that may be a two speed rear end. I believe I see the shift mechanism at the very edge of the picture.
Something else to consider in this equation is gearing of that three speed transmission. If you go too low ratio on the final drive with too large a tire, you may have a lack of gearing to get it in and out of a tight spot. Does a registration slip indicate what that unit weighs?
  #48
Old 05-18-2015, 08:13 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
....., from what I have read online though tubeless tires/rims are better than tubed versions. But if those 20 inchers will def work than it would be nice to have something almost exact on there to what was on there.
Yes, tubeless wheels are "better" to have serviced, and in the case of 19.5s would use radial tires that to many guys are preferable to bias ply. But, we never know what a guy's willingness is to spend money vs need to safely make do. The 20s without question will work on your axle, and save overall expense. The cheapest front axle fix would be junk yard 16s, but my buddy Mark can match your 17.5" or help with the 19.5" tubeless style. These, however, won't be inexpensive I don't believe. Stu
  #49
Old 05-18-2015, 10:30 AM
mokandshuk's Avatar
mokandshuk
Therre is only a reg sticker on the windshield from 1989. I do not have any of the former papers for it that would have the weight. About the tire size, yeah that is why replacing the 20 inchers that are on there now with those 20 inchers that are non widowmakers would be the best exact replacement. I would not have to worry about the gearing etc.
  #50
Old 05-19-2015, 08:53 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
Nice looking old truck, I didn't see where anyone responded to the question about the switch on the dash, if they did i must have missed it. Its an electronic brake lock. The truck might have lost the factory park brake with the rear axle swap and the electric one was installed to take its place. You should be able to find it plumbed into the brake line somewhere. I am also the guy with the set of 17.5s and set of 19.5s Stu was talking about. I will not split the 19.5 set but if you would want 2 of the 17.5s to match your spare send me a pm. I would agree with Stu that if your on a budget or don't care about factory hub caps, get a pair of junkyard 16s. If your plan is to run factory caps or just want something different than the 17.5s are the way to go. If you decide to go away from the 17.5s I would be interested in your spare.
  #51
Old 05-19-2015, 11:30 AM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
The brake lock you have on your dash in the picture was added to the truck post factory. When I was a kid in high school and college I worked for a lumber yard. All our big trucks had them. The brake line is routed to the dash to that lever lock. It will lock your brakes when sitting and idling. It is much better than an emergency brake, both the kind that uses the tranny or the kind that uses the drums. It was very useful on our lumber trucks that were flatbed dumps or high lift trucks. I wish my 1970 F350 had it.
Google Micro lever lock. They still make them today.
  #52
Old 05-20-2015, 11:57 AM
mokandshuk's Avatar
mokandshuk
thundersnow70 thanks for the reply on the Mico brake. Also yes, I would like the (2) 17.5s that way I have a spare on the front that matches the rims on the front. I shot you a pm. abe that gets me pondering that I will have to figure out what exact model that Mico lock is in case I need parts for it at some point.
I am set to buy the 20" for the rear, so I would have 20" non widowmakers on the rear to replace the 20" widowmarkers and 17.5's on the front to replace the 17" widowmakers
  #53
Old 05-22-2015, 06:07 AM
mokandshuk's Avatar
mokandshuk
  #54
Old 05-22-2015, 10:45 AM
ford_pickup's Avatar
ford_pickup
ford_pickup is offline
These Big Trucks are Awesome, I love them
  #55
Old 05-22-2015, 04:18 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
That sure looks like a two speed axle from a larger truck. Interesting. Most of those were geared for slow and slower.
  #56
Old 05-22-2015, 04:33 PM
raytasch's Avatar
raytasch
Believe Nothing
And that appears to be serious rust on the brake line that runs over the punkin. As Fred said, slow and slower.
  #57
Old 05-22-2015, 04:55 PM
truckdog62563
From the pictures in the Chassis Catalog the axle looks like an Eaton, obviously two speed. The book shows there will be a housing number and series identification on the rear of the axle on the passenger side tube near the differential cover. The Chassis Catalog contains a chart allowing us to look up the axle to identify weight rating, gear ratios, etc. Stu
  #58
Old 05-23-2015, 11:13 AM
mokandshuk's Avatar
mokandshuk
truckdog62563 you mean this one? I looked the other day and didn't see anything on it. I will go out and look again today. Also can you message your friend with the 17.5s. I left a message on here for him and pm'd him but have not heard back.
http://www2.dana.com/pdf/AXSM-0040.pdf
  #59
Old 05-23-2015, 12:11 PM
truckdog62563
Your link is for Dana axles, but from your pics I think you have an Eaton matching this page from the 1964 copy of the Chassis Catalog. If you can find coding on the housing or axle tube we might be able to figure out what you have.
I'll text Mark and have him get with you on the 17.5s. Stu
  #60
Old 05-23-2015, 12:16 PM
mokandshuk's Avatar
mokandshuk
From last weekend:
Doesn't seem to be any markings there but I will check again today.
Quick Reply: 1955 Ford F250 Custom Camper w/1964 390 Police Interceptor
