'48 F1 - Home, First Drive, A few Questions
#61
#63
#65
I did not use Teflon tape on the connections I've touched...however, I'll have to check on the connection to the tank which was done by the PO. It may have Teflon on there.
#67
#69
2x on Forty-niner's earlier post. I had a clear sight glass, and flow when disconnecting the line from the elec. pump to the tank. But the engine just wouldn't pick up well upon demand. Put 50 psi through it until hearing bubbles in the tank, let it flow again, repeat. Flow through the line doubled, problem solved, at least, until getting around to putting in a new tank.
#70
Connected the line back up and running well again. Not going to call it perfect yet, but hopefully will get me by until I can clean out the tank or replace it.
#72
Drove 20 miles on Monday, longest ride yet. No problems. Put some gas stabilizer and gas in the tank.
Tuesday afternoon, drove another 20 miles to put the truck in storage while we go to Michigan for the summer. We're trying out being 'snow birds' this year and see how it works for us.
Temperature outside was 100F and 100% humidity (must be time to head north!). Had the vents and windows open as well as the cowl vent and was still dripping when I got there. Temp gauge went to its normal slightly above the half way mark, then when I got up to 45 to 50 MPH, crept up to just below the H.
I was afraid it was going to over heat, but it kept running like a champ. I slowed down a bit to see if it would cool off, but it didn't budge. It was running great, so kept going.
Said goodbye to the truck for about 3 months.
Muchopesos
21
03-12-2016 05:03 PM
Rentaro
16
07-23-2013 08:27 PM
