help!! frustrated!
help!! frustrated!
i have a 1992 ford f150 with the 5.0l v8
the problem:
my truck "was" running great, never really has given me problems.
the other day i was comming home from errands, as i was getting on the on ramp to go home, the truck just died. there was no spitting or sputtering, no hesitation, its like someone just turned the key off and threw it out the window.
i tried to restart, nothing. after towing it home and messing with it, i found a blown maxi 20a fuse for the ecm was blown. replaced it, still nothing. everything in the truck works, but my fuel pumps dont cycle on and i have no spark. ive checked every fuse, all my conections, everything is fine. i took my computer out and noticed a slight discoloration or burnt looking mark by the capacitors. i replaced my ecm 3 years ago because of the same issue. could this be the problem? or something else. i have no idea what else to try......thanks in advance!
the problem:
Sounds like you found the problem. If the board is discolored it may just be electrolyte leaking from the capacitors, if it's a burn mark well that's self explanatory. In either case if the traces on the board are intact or only slightly damaged you might be able to save it.
It could be the ECM and it should be easy enough to come up with another one to try. Try the scrapyard first. This is an expensive part to just throw at the problem if you are buying new.
However, it is extremely rare for the ECM to suddenly give up and blow the fuse the way you describe. Anything is possible, but you have a long list of possibilities other than the ECM. Blown fuses are caused far more often by damaged wiring than they are by component failure. Get your meter out and check for power at pin 1 of the ECM connector. (Heavy yellow wire). Get a wiring diagram to assist with other checks.
Can you read codes? If you can, it is an indication that the ECM is at least powered up and running. If you can read codes, is there anything other than 11?
Discoloration on the board is caused by heat. If it is around the capacitors, they have heated up at some point. Since you replaced the ECM previously, this may be old damage, especially if your ECM was "rebuilt" by replacing capacitors. A discolored spot is not necessarily fatal.
Can you run the fuel pump by jumping the test connector? That would prove out fuel pumps, relays and associated wiring.
Littlebuddy
02-21-2004 08:44 PM
wesmansr
07-09-2002 03:47 PM
