Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
Front driveshaft wont turn by hand
Old 05-10-2015, 08:54 PM
btorear btorear is offline
btorear is starting off with a positive reputation.
Ok, I've searched the forums which only lead to more confusion. Some say the front drive shaft should turn by hand in 2h and some say it shouldn't.... I have an 06 FX4, with auto locking hubs (meaning if I want 4H i turn the **** from 2H to 4H). I've been getting a terrible shake at 55mph (yes I've read the forums on that too, not my question) So I crawled underneath to look at rear driveshaft, u joints, etc..., and by chance I grabbed the front driveshaft to pull myself forward to check out everything else, and it didn't turn......I twisted a little and the shafts going to both front wheels turned. Now shouldn't these turn freely in 2H?....The light to 4H never comes on when I switch the ****, but it is engaged (or else I'd never have gotten unstuck....several times)... Am I stuck in 4H and just didn't know? .Any help would be greatly appreciated.
Old 05-10-2015, 09:21 PM
I get the audible "click" when I turn the **** from 2H to 4H, and "click" again when I switch it back to 2H. Crawled under and wiggled the wiring harness that goes to the electric motor that engages 4x4 and the 4H light came on,flickering.....Just thought I'd add that....
Old 05-10-2015, 09:56 PM
papasmurf40 papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
Ken Kilpatrick
If truck was off and no vacuum to front hubs the hubs are locked. Either use a vacuum pump and try again or start truck and with someone pushing brake for you or parking brake on try turning the shaft and i believe it should turn.
__________________
Ken Kilpatrick
2008 F150 FX4
Old 05-11-2015, 05:59 AM
Started the truck, and got underneath. still won't turn. Does it need to be in drive with someone pushing the brakes? I had to do this with the truck in park.... You mentioned someone pushing the brake or setting the ebrake (which doesn't work in my truck for some reason).
Old 05-11-2015, 08:03 AM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 is gaining momentum as a positive member of FTE.fordman19762003 is gaining momentum as a positive member of FTE.
Quote:
if the truck is running you should be able to turn the front driveshaft no matter what position the tranny is in. If you can't something is binding up, maybe you have no vacuum pressure going to the IWEs and they are always locked in or maybe your t-case is stuck in 4wd.
With the truck running and in 2wd pull the vacuum lines off the IWEs and you should be able to feel a slight suction on the end of the hose. To check the t-case drive slow on a hard surface and make a sharp turn if the t-case is locked in 4wd you should feel a lot of binding while you turn.
__________________
my truck-2013 F250 XL RC 4x4, 6.2L, 4.30e-lock,285/70/17 BFG AT's
wifes truck-2012 FX4 SCREW,3.5, appearance package,1.5" AS leveling kit, 275/60/20 Hankook ATM's
Old 05-11-2015, 09:51 AM
Took a chance and went ahead and bought the $30 solenoid at autozone on the way to work. Changed it out during my break. Problem solved. Bought the truck in November 2014....hubs probably been engaged since I've had it. 4H and 4L lights both come on now. Since that front shaft has been spinning, it could explain my vibration at around 55mph.....we'll see on the way home from work, I suppose.....Thanks to all for the help
Similar Threads
Havin problems with my 4x4 80ford100 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 05-17-2015 06:47 PM
H.(Hodgepodge)I.D. install Apocalypse Excursion - King of SUVs 7 12-05-2014 02:41 PM
Sorry but yet another high boy power steering question. H 3 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-19-2014 03:57 PM
Shaking when turning in 4x4 Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 3 05-27-2014 01:14 PM
Full Time Transfer Case or NOT 74FordCrewCab1stimer Clutch, Transmission, Differential, Axle & Transfer Case 1 03-03-2014 07:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
