What is this?
Old 05-10-2015, 08:10 PM
gabescanlon's Avatar
gabescanlon
gabescanlon is offline
What is this?
Took off my intake manifold, never seen this before? ( I'm new to this obviously ) just replacing the manifold.
Old 05-10-2015, 08:11 PM
gabescanlon
Also!
****Revise****
Does any hose plug into it? Also, where does the distributor wire in the middle plug into?
Old 05-10-2015, 09:32 PM
skidoorulz's Avatar
skidoorulz
skidoorulz is offline
You obviously have a Y block. That is the crankcase vent it hooks up to the PCV valve that is screwed to a fitting on the intake manifold in front of the carb. The hose goes to a metal tube which runs along the right valve cover and there is a 4 inch hose that connects the metal tube to the PCV valve.
Old 05-11-2015, 12:21 AM
gabescanlon
Do I have to hook it
Up? Or can I just leave it and yse it as a ventilator for the crank case? Because idk where where to hook it up..
Old 05-11-2015, 02:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C1AE-6A665-G .. 292 Crankcase Ventilation Adapter / Obsolete
1961/64 Trucks & 1961/63 Passenger Cars.
Illustrated as 6A665 in upper pic:
Old 05-19-2015, 07:35 PM
Cazman1955's Avatar
Cazman1955
Cazman1955 is offline
The answer to this part of your question is: it hooks to the ignition coil.
sseebart
12-28-2023 10:38 AM
Shadowrider123
16
09-09-2016 05:57 AM
Fordbyford
1978 - 1996 Big Bronco
07-11-2005 05:15 AM
youdog99
11-27-2002 04:12 PM
Quick Reply: What is this?
