no crank both batteries have 12.4v and relay has 11.7v
Old 05-10-2015, 10:56 AM
MONAVIERONJON's Avatar
MONAVIERONJON
MONAVIERONJON is offline
how can this be? the WTS cycles as well as glow plugs. Brand new batteries, starter relay, starter. with a volt meter tested to make sure power is going to both connections to starter and they are good.cleaned battery posts, and all connections, is it that if there isn't 12v going to starter it wont function? only 3 codes: 0237, 0470 ( deleted EBPV), 1139 (unplugged fuel heater). 2001 f550 150k a/t. thank-Q
Old 05-10-2015, 11:03 AM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
Are you saying the starter won't engage, or the truck turns over and won't fire off?
You can check your starter by jumping the relay. This will confirm the starter is good, or at least getting the juice.
If it will turn over but not fire, put a charger on it for a clouole of hours and give another try.
Report back.
Old 05-11-2015, 08:12 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
If it's not turning over put it in neutral. It could be a sloppy shifter.
Old 05-11-2015, 10:49 AM
MONAVIERONJON
there is power to the relay, have a test light and ohm meter, perhaps these batteries have the volts and not enough amps. had that before when the lights are on and all that but what is really needed is the amps to turn the starter . these require 1650amps with factory starter and 650 with denso style. I only use denso style . thanks
Old 05-11-2015, 10:07 PM
MONAVIERONJON
it fired up when i swapped two other batteries in there and jumped the relay, seems like there is some stray voltage in the ignition circuit , gonna have to chase some wires.
Old 05-12-2015, 06:46 AM
Thomas White's Avatar
Thomas White
Thomas White is offline
You need to determine the voltage drop during cranking. This is best done by using the Solenoid with the key out of the ignition so it doesn't start.
Here is a diagram you may find helpful to ease the process. Simple to make and works on all vehicles.
0.5vdc is the maximum drop.
Old 05-12-2015, 08:28 AM
bigb56's Avatar
bigb56
bigb56 is online now
Is it one of the Chinese made Denso style starters?
Old 05-12-2015, 10:31 AM
MONAVIERONJON
it is, the engine i swapped from an e350 with same starter that functioned well and i drove that van for 2 years. actually unplugged the ICP and it started so it could be a few things.
hyper3199
1997 - 2003 F150
12-14-2016 05:01 AM
OFD2413
07-11-2015 08:53 AM
jcanavan
1983 - 2012 Ranger & B-Series
05-21-2013 10:32 AM
ducksoup
04-05-2011 08:24 PM
johnsteffy
12-09-2010 07:01 AM
Quick Reply: no crank both batteries have 12.4v and relay has 11.7v
