Maximum Tire Size
You can look at the tire manufactures websites for recommended wheels for various tires widths. The factory wheels are 8" wide. I got after market wheels of 9" width because the 295/65r20 recommend something wider than the 8" for it's optimum wheel width.
There are folks who run the 295's on the factory 8" wheels. I tow heavy and am concerned about squeezing a tire under load. Their tread life doesn't last as long. If you run empty most of the time, the 8" squeeze is not a big deal. If you are loaded. it is.
I am thinking about 37s on stock 8" wheels. For example, Mickey Thompson ATZP3 in 37x12.5R20. This is only .5" under recommended minimum rim width for that tire (8.5" - 11"). What are the issues that need to be dealt with? I am willing to go to a minimalist aftermarket bumper (e.g. ADD bumper) to solve front bumper bracket rubbing.
If I could find a narrower 37" tire, I would go with that, but I don't think it exists...
I'm sure others with more knowledge will chime in, But the big problem with using a narrow rim is that you squeeze the wide tire onto a narrow rim and its now difficult to get the tread flat against the road. This causes it to wear faster than it should. Especially if loaded.. If you run empty, not as big a deal. But if you carry a load. your tires already wear fast as is, I don't need them wear out any faster.
scottddove
02-24-2009 02:56 AM
marks79f100
01-23-2004 09:57 AM
