Turbo or not
To the OP, ask about the SCAs in the coolant. The 7.3 IDIs were known for cavitation if the SCAs weren't kept up.
Received 3,101 Likes
on
No, the '94.5 and newer is the same, the '93-'94.5 IDI turbo was a completely different motor from the PowerStroke.
To the OP's original question, the answer is turbo if all else is equal. The factory ratings are inaccurate, and reasonable power is a non-crushed downpipe and fuel increase away. Mine's had over 16k behind it, pulls like a champ.
From my reading the 93 94 IDI T was a good bit better than a stock IDI non T. There were some changes to it that were made specifically for a T that made it more durable for T power and you should be able to run more boost without problem over a stock IDI with a after market Turbo.
The problem with the IDI Fac T was they only made it for a year and a 1/2 so parts are very limited.
on
