2005 F350 replacment parts? where to find
My dad gave me his truck, it was a work truck and is beat up really bad. I'm trying to restore it a little bit and make it a nice truck again. it wil ljust be a "farm truck" so i'm not going crazy with this
I can not find much info on the below issues:!
BED
It really needs a new/used bed, where can i get one? is it cost effective? don't really care on the color reg cab 8 foot bed
Seat
I need a new seat, the foam is hanging out and it smells like gas/oil and trees lol
GAS filling
it will not take gas, have to use a funnel and slowly fill it, i'm talking not even one click on the pump!, takes easily 20-30 minutes to fill the tank from 1/4 full witch is about 25-26 gallons
BED
Seat
GAS filling
Not sure where you're located but out here in California where rust hasn't been invented yet I'm always finding beds on craigslist. I would also look there for your seat.
FUEL FILL
Most likely it's the vapor canister. 05 - 07 F250's had this problem in dusty or dirty conditions. Here's a link to a posted FTSB about the problem:
06-19-15***SLOW FUEL FILL
Rockauto.com has the best prices on the complete assembly $230.00 BUT I removed my vapor canister & back blew both the air box and the carbon canister part at work. I actually taped 2 separate air nozzles to each one and let it run the entire work day. I can now lock the fuel fill nozzle on the slowest fill setting & walk away while my tank fills. - To drop your Vapor Canister you will need to drop your spare tire, remove the spare tire hoist assembly (4 bolts if I remember correctly) and if you look up you can see the Vapor Canister assembly mounted crossways from frame rail to frame rail. Another 4 bolts and it comes out. On the drivers side where the vapor line connects to the air box there's a connector right at the frame you will need to disconnect. If you clean it off you will see a green plastic squared off horseshoe release - Press down at the top and pull the Vapor Canister rearward. Hope this information helps.
FUEL FILL
If you want any new Ford parts and would like to keep
more of your own $ in your pocket give Ed at FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
They have some very good pricing and fast shipping and good prices on that too.
Sean
Sean
Paul_inCT
1999 to 2016 Super Duty
35
01-10-2019 08:16 AM
Cody_1948
49
05-14-2013 01:55 PM
