Power Window Wiring Question
The rear passenger side door's power window on my 2001 F250 Lariat Crew Cab stopped working. As you know, power windows can be operated by either the window switch right on the door OR from the switch that is on the driver's door. In my situation, the rear passenger side door's power window will not work using either of these two switches.
Does anyone know if a bad window switch on the driver's door will prevent the window switch on the rear passenger's side door from working also?...or visa versa?
Right off, I am assuming the power window motor is bad (absolutely no noise coming from the door when I toggle either switch), but I thought of this other possibility also.
Any insight would be helpful. Thanks!
Dave
Dave
Texasdeereandhorse
1999 to 2016 Super Duty
05-02-2019 09:12 AM
FERdter
05-28-2018 12:19 PM
ncernitz
12-27-2001 05:19 PM
