Replacing the alternator?
Went to start my '99 V10 E350 van (for the first time in a few weeks) this morning and there was a high pitched squeal from the engine area. Gave it a bit of gas and all quite. Battery light came on. Shut it off and found the fan belt was hanging off... snapped.
Tried all the pulley's the belt came into contact with and it was clear the alternator was seized. Guess my weekend is already planned out for me
Fairly straightforward job is it? Looks like I can get to it after I remove that top air intake "bottle".
What do you use to pull on the tensioner to install the fan belt?
Any brands of alternator's you find more reliable?
Thanks for the help!
Maple's idea of finding a qualified and high-quality alternator rebuilder is great----they often times can reman alternators to better-than-new specs with much better components too. Check your local yellow pages for someone who does this.
OR I've used NAPA's best quality alternators with stock output/capacity and have nothing but great experience. At that level you have lifetime warranty too.
Definitely do NOT scrimp on the belt---NAPA also has good quality for about $40 last time I needed one.
HTH
HTH
I'd opt for the rebuild if possible.
Taking a look around it appears "rebuild" can mean several things. A complete rebuild includes bearings, brushes, rectifier and voltage regulator. That last part can be very costly ($50 - $60) and some do not mention they offer to install a new one.
One place offered me just bearings and brushes for $130. Seems high.
I was also told if mine is seized it may be hopeless as it may now have a damaged stator. Odd this happened so quickly since I had no waring it was going. No noise of any kind up until yesterday when I tried to start it.
Have yet to pull if off to see how bad things really are.
Typically you'll find the better repair operators are those specializing in big trucks or industrial equipment. Vehicles like vans and/or pick ups are pretty much small potatoes to them but even so they'll do a good job.
You should receive an offer to do something simple and cheap or more extensive priced accordingly. $130 for brushes & bearings only is high---I'd keep looking around.
If all else fails there's always new!
a rebuild kit is only around 30 bucks
All you have to do is make sure the stator is ok
3G | Alternator Starter Rebuild Kits
Kit contains new brush holder/ voltage regulator assembly. A new slip ring, new bearings. New pulley nut and lock washer.
Sixto
93 E150 Chateau 5.8 190K miles
4x4Mark
11-13-2008 06:00 AM
FordFan19
07-30-2006 10:26 AM
