The riff raff set don't have it unfortunately. But using rtv is what I had figured I was gonna have to do. The old gasket was half missing which means that it eent through the motor so rtv sounds better to me.
yeah, you order that separate.
I just put a bead of grey silicone on mine, the weaker stuff. it just needs to make an air tight seal.
To get it broke loose, juts use a heat gun.
Some people think you need to use them, *shrugs*
Well it's all back together and hasn't blown up yet but after a short drive one of the new up pipe gaskets seams to teak a little so when it cools down should I try and retighten it? Also they were smoking quite a bit but I believe that's normal.
IIRC, you gotta tighten them when they are hot.
But I don't remember.
