Turbo off. What now?
Old 05-08-2015, 11:41 AM
wolff7.3's Avatar
wolff7.3
wolff7.3 is offline
Nice cowmilker08! But does anyone where to get the compressor manifold gasket at? I can't find one anywhere!!!!!! And mines junk
Old 05-08-2015, 11:47 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Old 05-09-2015, 03:51 AM
Talyn's Avatar
Talyn
Talyn is offline
The big o-ring around the compressor side?
Not necessary if you dont want.
Just use a small bead of RTV around it if you ask me.
But thats my opinion.
Old 05-09-2015, 09:54 AM
wolff7.3's Avatar
wolff7.3
wolff7.3 is offline
The riff raff set don't have it unfortunately. But using rtv is what I had figured I was gonna have to do. The old gasket was half missing which means that it eent through the motor so rtv sounds better to me.
Old 05-10-2015, 09:55 AM
Talyn's Avatar
Talyn
Talyn is offline
yeah, you order that separate.
I just put a bead of grey silicone on mine, the weaker stuff. it just needs to make an air tight seal.
To get it broke loose, juts use a heat gun.
Some people think you need to use them, *shrugs*
Old 05-10-2015, 10:37 AM
wolff7.3's Avatar
wolff7.3
wolff7.3 is offline
Well it's all back together and hasn't blown up yet but after a short drive one of the new up pipe gaskets seams to teak a little so when it cools down should I try and retighten it? Also they were smoking quite a bit but I believe that's normal.
Old 05-11-2015, 08:56 AM
Talyn's Avatar
Talyn
Talyn is offline
IIRC, you gotta tighten them when they are hot.
But I don't remember.
MONAVIERONJON
05-03-2017 04:07 PM
noshow
12-06-2010 03:37 PM
Douglas DC-9
03-25-2009 11:23 AM
guthrie&co
10-16-2005 10:41 PM
Tarzan
02-26-2004 08:52 AM
Quick Reply: Turbo off. What now?
