Diesel exhaust fluid warning message
I have a 2011 f-450 6.7 - truck has 70K miles. The other day I was driving and the message said "Cleaning exhaust filter ". I usually keep it running a little to finish. Then shorty after a warning message came on which said "800 Miles to Exhaust fluid empty". So I went to fill tank and it was FULL. Now the warning keeps showing up each time I start the engine. It now says 300 miles to empty. I'm afraid it's going to go into limp mode even though the exhaust fluid tank is full. Anybody experience anything like this? Appreciate any suggestions, thanks
When was the last time you filled it? If it's been a while and it's still full maybe it's not injecting properly (or not at all), and the computer senses this? I'm just guessing here. Mine is brand new, and it haven't added any yet so I'm not sure if it re-sets itself, or is there a way to do it manually. If not, I'd get it checked quickly. Good luck.
cant say for sure as i dont have one... but im wondering if maybe its like the "oil change reminders" they had on the vehicles near the early 90's.. where its just going off miles and not an actual sensor. Could be you just need to reset the DEF trip reminder. Of what ive heard the systems supposed to be "refilled" at every oil change. If you havent looked in the book for such a thing may want to look there..
As i said im just guessing since you said the tanks full and its still counting down.
Received 3,988 Likes
on
I have a 2011 f-450 6.7 - truck has 70K miles. The other day I was driving and the message said "Cleaning exhaust filter ". I usually keep it running a little to finish. Then shorty after a warning message came on which said "800 Miles to Exhaust fluid empty". So I went to fill tank and it was FULL. Now the warning keeps showing up each time I start the engine...
As a few of the other folks have suggested, it sounds like it's time for your dealer to take a look. Since the warning is popping up every time you start the truck, it should be pretty easy for your tech to replicate. Circle back and tell us how things go at your appointment; I'll be here to help after you receive a diagnosis, if needed.
Crystal
Def Warning message
Hey, I appreciate everyones quick response to my problem. Some involved LOL
I have a Ford dealer in Millersburg OH who is really trying to get some input from Ford and also arranging time for his mechanic to look at the truck. We are traveling with a fifth wheel trailer and don't want to head out again till its resolved. One dealer rep said it could be pump, tank or sensors. Anyway, thanks to all for your idea's. I did initially try filling the def tank with the Pilot pump and nothing went in so I also have the jugs with the Ford filler spout which also didn't allow any into tank so I pretty much know its full. Again, thanks to all and I will let you know the outcome soon.
Def repair done
The problem was evaluated at the ford dealer and all details were submitted to Ford for warrantee approval. It was approved under my extended warrantee. The def tank had to be dropped down and the pump inside was replaced. Apparently there are two pumps with one outside also according to the service advisor. They might have replaced the module on top of tank too. There was a lot of technical terms on the paperwork I received so not really sure how to explain the repair and parts involved. Anyway, back on road and all seems good. Thanks again to you all who follow these threads to help novices like me.
Def fluid warning
That is a bit of mis-information there. I have run mine dry one time. Not on purpose and not for many miles..many 50 or so miles.
You get the warning of reduced speed when that happens.
Once filled back up the warning goes away.
Not recommended as it will shorten the life of the pump. I had no choice when mine ran dry for a few.
