Front Parking light Assembly
Can someone tell me can the socket be taking out of the shield in the front Parking Light Assembly. I have tried everything to get the signal light to work..I have power cause the parking light come on but can not get the signal light to work..so I thought maybe I could replace the socket..but not sure how to get it out. Any help would be great..
Twigs, I don't think so. There are 2 hot wires going to the socket, one for the parking the other for the turn. Try swapping the bulb from the other side if it works, could be the bulb. Try cleaning the contact point it could be dirty. Do you own the ice pick looking circuit tester? You can place the point in tight places to see if you have current or not.
Don't give up yet.
John
Don't give up yet.
John
Don't give up yet.
John
Don't give up yet.
John
C5TZ-13207-H .. Left (drivers side) Park Lamp Body / Obsolete
Applications: 1965/66 F100/750.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-652-3241.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
PEROGIE ENTERPRISES in Highstown NJ has 1 = 609-448-5593.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
Ah ..that is a good Idea...
Yes, because 1961/64 parking lamps are completely different and are located within the grille itself.
1965/66 parking lamps are located in the panel above the grille...known as the upper grille panel.
The pic in post #6 is from the 1964/72 truck catalog. Notice that the caption in the upper pic that shows the lamps says 1965/66.
