03 windstar rear brake thumping
Old 05-05-2015, 10:00 PM
jlshady00's Avatar
jlshady00
jlshady00 is offline
Exclamation 03 windstar rear brake thumping
I'm having an issue with my wife's van, every time you apply the brakes the rear passenger side brakes make a loud thumping noise like it's catching in one spot. I cannot figure out what the issue is. It began when I changed out the drum and shoes and hardware. As of now, I have installed new drum, new springs/hardware, new shoes, new wheel cylinder, new hub assembly, and even a new parking brake cable for that side. I exchanged the drum for a new one thinking that was it, still persisted. I swapped the drum with the driver side which didn't help, swapped the wheel and tire from the front passenger side, didn't help. I re-installed the old shoes, and it was making the noise before I decided to swap the cylinder. So, i don't believe it could be the cylinder, drum, or shoes, but I am at a loss. If I spin the tire with it in the air it catches slightly in one place, but I can't figure out WHY! Does anyone have ANY idea what could be causing this? Any help would be greatly appreciated!
Old 05-10-2015, 05:22 PM
1saxman's Avatar
1saxman
1saxman is offline
You mixed up the shoes (reversed).
SkoalDipperJoe
20
01-20-2016 01:18 AM
hiroller
Escape & Escape Hybrid
08-03-2014 11:34 AM
BAD RONALD
06-14-2011 02:08 PM
bmiller44685
1983 - 2012 Ranger & B-Series
07-12-2008 09:05 PM
83sd
05-27-2005 12:20 PM
Quick Reply: 03 windstar rear brake thumping
