Oil Change
With the drain plug, just make sure you have a oil pan with the capacity of atleast 15 quarts, cause once she is coming out, it's coming out fast, especially if warm. Fill tube is on the passenger side, against the firewall, I have a funnel that hooks onto the firewall so it doesn't tip over full.
I thought I had a big enough container, made a approx. 2 qt mess, oh well that is what speedy dry is for. My funnel fit perfectly on the fill tube and didn't loose a drop of the new expensive oil!
df85732
09-18-2016 11:33 AM
