Question on AOD for 8BA
It doesn't have it, some trucks that had manual throttle have 1/2" - 3/4" of the throttle shaft sticking out. You would be able to fab a lever off that.
There are two flatheads in the local EFV8 club with AODs behind them, but both are blower motors with 4-bbls, so no help there.
Replace your throttle section of your existing carb with this:
CL-94-P-ALUM
Can't link directly, it's on Vintage Speed's catalog under 94 Parts
$119.00. It has I believe larger throttle bores than a stock 94, might need to clearance your manifold a little or just run double gaskets. Then figure out an arm that will clear the bowl.
CL-94-P-ALUM
Thank You!
RON"
I found that Speedway sells an adapter from the 3 bolt to a 4 bolt that fits a Rochester 2CG carb, so it won't fit a Ford or Holley. They also have an adapter from the Holley base to the Rochester carb. I'm trying to find out if that will work the opposite way.
I would call Vintage Speed, they aren't known for being responsive to emails. From my perspective, no question you can use their base section with the longer shaft, but you'd have to adapt an arm of the right length to the shaft and rig up a way to anchor the cable-type AOD throttle valve.
I ran a 2110 on my stock manifold for a number of years, no problems. The 2G solution isn't viable, they get mounted backwards so all the throttle arms are on the passenger side.
Sorry, I misunderstood about the "2100", you are talking about the Autolite 2100 I believe. Like used on SBF's in the 60's? I'm sure only an aftermarket manifold will fit them, unless you make your own adapter.
The Holley 2110 (sometimes called a 2100 or ECG) has the same bolt pattern as a 94 but bigger throttle bores.
I'll ask around the guys I know with AODs on their flatties, even tho they are blower motors they may know some trick to do it.
As I mentioned before, Speedway has This adapter Late Carburetor Adapter - Free Shipping @ Speedway Motors to convert the FH 3 bolt to the Rochester 4 bolt. They also have this adapter Holley 2300 to Rochester 2G Two Barrel Intake Carburetor Adapter - Free Shipping @ Speedway Motors that adapts the Rochester 2G to the Holley 2300. And they also have this adapter Universal 2 Barrel Carburetor Adapter - Free Shipping @ Speedway Motors That fits multiple carbs.
The multiple adapters would wind up also acting as spacers, so I'm not sure how that effects the motor.
The sad part is that I contacted three different transmission adapter companies before I bought the transmission, doing my research and asked specifically about the carb, they all said that many folks have set them up with that carb.
See below. "Krylon32" is the Cornhuskers guy. From other threads it sounds like he is running a 4-bbl.
aod trans behind flathead - The Ford Barn
#29
You keep using the term "kickdown" and are talking about running a 2100 with an auto. Bear in mind these kickdown linkages will not work with an AOD. Nor will a 'Ford' Holley with a kickdown linkage. The AOD needs a "pull" not a "push" as most stock non-AOD kickdowns are.
Lokar makes a kit, but requires some sort of linkage to PULL the cable. Ross suggested an extended throttle shaft for the 94 - speedway sells them for $15.99:
Ford/Holley 94 Extended Throttle Shaft - Free Shipping @ Speedway Motors
Use this and an arm like this:
Aluminum Throttle Linkage Arms - Free Shipping @ Speedway Motors
Then you can install the Lokar TV cable - you may have to fab/mod the carb side of the bracketry, but that shouldn't be a big deal. You want to have the TV arm attach point for the cable be a 1:1 movement of the throttle. So it will need to be the same distance away from the centerline of the shaft as the throttle ball is.
#30
