TMeyer ZF5 Adaptor For 335 Series Engines
That's exactly what we have to do.
You should be a machinist!!!
1st operation will be on the mill, face the material, drill holes for the crank bolts, drill and tap for pressure plate holes.
2nd op will be bolt material using the pressure plate holes to a face plate in the lathe and machine block side.
3rd op, flip and machine flywheel face and recess in the middle.
4th op, add balance weight and spin to confirm correct imbalance.
5th op, install ring gear
6th op, surface grind flywheel face.
In theory...
In theory...
LOL! One of the things I like about machine work is the chess-like game of figuring out how to do the work. And that includes not removing the work from the machine, lathe or mill, as it'll never go back the same way. (Yes, I know that with a 4-jaw chuck you can dial it in, but....) So, there's a lot of planning before any chips fly.
I am starting a list of people interested in a billet flywheel for the ZF5 conversion. Email me @ fordmachinist@gmail.com if your interested.
Well, Brandon, mine ran to Delaware and back, plus lots of other miles with nary a problem. Probably a total of 5,000 miles. But there's nothing to go wrong, really. The flywheel will be positioned in the 460's original position, and take the 460's clutch and pressure plate. So, as long as it is machined accurately so it runs true, and is well balanced, it'll work.
Still rockin' my TMI 400 & ZF5
This is a great solution guys!
Been driving the wheels off of my 'ol 78. Ran 75 MPH down the highway at about 2600 rpm today with my 35" tires and 4.88 gears. Still makes me smile to be able to shift the stick up and to the right going down the highway.
I have had zero issues related to the way I installed my ZF5 and probably have around 10-12k miles on it, many of those miles are flogging on it pretty hard.
I have about 3/8" of engagement into my 460 style pilot bearing.
That said, Building a "swap specific" flywheel will make things so much easier for the next guy.
Go for it Tim & I'll help spread the word, plus if I ever have to pull my trans again I would be willing to "upgrade" to your flywheel.
https://www.ford-trucks.com/forums/1...f-5-400-a.html
https://www.ford-trucks.com/forums/1...i-400-etc.html
#29
#30
As you can see from Tim's pic, the ZF stick attaches via two bolts. So you could saw the NP, or any other, stick off and weld on a flat piece with the necessary holes. Having done that, you'll then have to figure out how to adapt the ZF's **** to the NP, or other, stick. Or, those who attempt to drive the truck will do bad things to the tranny.
