TMeyer ZF5 Adaptor For 335 Series Engines
#32
#33
https://www.ford-trucks.com/forums/7...-pictures.html
And to Gary's concern about the wrong shift pattern on the ****, if the 4 speed has reverse to the right and back, the only thing wrong on the **** would be that it wouldn't show that ther is a 5th gear (or where it is obviously). But everything it did show would be correct. (On the other hand, if the 4 speed had reverse to the right and forward...)
#34
That's a good post! After reading that, I have a question regarding the torque rating and TMI's stroker engines. Can the ZF5 S-47 handle the torque output of Tim's 434 stroker? I know it is a truck transmission as it will be going into my 79 F250 4x4 so I'm not expecting quick shifts, it's the torque load I'm questioning.
#35
The "-47" stands for a rating of 470 ft-lbs. And the "-42" is rated at 420. Will it hold up to a 434 stroker? Dunno, but I'm putting a -42 behind the 400 I'm building for Dad's truck, which Tim guesstimated at 500+ ft-lbs. My bet is that I can't couple that kind of torque to the ground so will never stress the tranny. Even towing I find that I spin the tires on Rusty with the 351M that's in it, so the 400 will as well.
Ford put these transmissions behind the 460's and diesels, and they seemed to survive quite well, so I'm not concerned.
#37
forddriver17
03-14-2009 12:00 PM
rollinclassic
12-05-2007 10:56 AM
Gidde Up
04-28-2003 10:43 PM
