Lets see those 5th wheels
#586
How do you like that front living Doug? We looked at a few of them before we bought ours. We also saw the newest front kitchen with a big window in the cap. Way out of my price range, but nice!
#587
Mods to my Montana 5th wheel..........
Did some upgrades to the Forward Storage Compartment...........
A Water reel for fresh water connection. This reel connects directly into the FW's water system.
I have to get a male connector for the hose. Then it connects to the Bronze fitting.
How did you attach those 1x4's to the aluminum floor joists? Or did you bolt through the 1x4's from the reel to the joists? What bolt/screws are you using?
Looks like a typical hose reel from the department store, just turned upside down?
Did you run a potable water hose from the reel to your water inlet for the trailer?
I like the idea. Don't know if I can make it work, but it would be nice to get my water hose out of a storage container.
#588
Two coaches pull out into beds and there is a dual recliner facing the tv
#589
Roy, I am interested in that hose real setup.
#590
Received 3,997 Likes
on
The hose from the reel to the water inlet of the FW (5th wheel) is the short connector hose that came with the reel. Had to cut off on of the FM ends...push the hose through the wall between the beg compartment and the small control center compartment. (I had drilled a 7/8" hole in the top of the control center compartment) Then I attached a Male brass fitting to the end of the cut hose. This attaches to the water inlet to the FW. (I used an elbow there).
What I have not done yet but will.........
Putting the drinking safe (White) hose on the reel.......The hose must be put on backwards.......the Male end must be attached to the Male connector in the center of the reel. I have a FM to FM brass coupling.connector for that.
The FM end of the hose will then be pulled from the reel and connected to the fresh water supply at the campground. To do that, I am going to drill a hole (probably 1" dia) through the side of the control center compartment. That way the hose comes from the reel.....through the control compartment wall.....into the control compartment......through the 4" hole built in to the bottom of the control compartment.....out the bottom of the FW.....on to the fresh water faucet at the campground.
I'll post more pictures as I finish.
#591
on
#592
on
The front living is growing on me. This like most other big ticket items, I'm just a signature. Wife fell in love with it, now it sits in driveway. It also came with a bigger TV than what I have in my home.
#593
#594
#595
on
Mods......Montana FW
#597
on
#599
Received 5,160 Likes
on
