Losing a quart of oil every 500 miles
So about 2 weeks ago I did an oil change on the old Ford, yesterday before I had started it up, I checked the dipstick and it was already a half quart low and it's been 279 miles since I just did the oil change. I know the passenger side valve cover gasket is leaking, but any ideas where the other bit of oil is going? The only time it burns oil is the little bit that drips on to the exhaust manifold and that's it. I've checked under the truck for drops and nothing. I'd expect about a quart of oil every 1000 miles or so but with 260,000 miles I think the old truck is on its last life.
Currently I'm looking for another truck anyway so my dad can have the truck back for himself...need something that gets better than 12mpg on a good day.
try replacing the the PCV, not with a el-cheep-o aftermarket one, as these tend to not works as well. You'll need to get a Motorcraft one as see if things improve.
Is the tranny gaining fluid? or the radiator gaining? trace down the oil that is leaking on the exhaust to its source. What all has been done to correct this so far?
I bet dear ole dad would appreciate you trying to get things back to a reasonable rate before you hand the keys back.
Not much really. Transmission hasn't gained any oil. Somehow the truck is loosing about half a coolant res. of coolant about every couple of months even after adding Bars stop leak so probably a cracked head there. The oil leaking on the exhaust is from the passenger side valve cover gasket...would have replaced that but with how old the truck is the bolts are severely rusted and will snap if I even try to get a socket or wrench on it.
Truck is still under his name for insurance and everything...other than putting gas in the tank, changing oil and doing maintenance to it everything else is up to him for the truck, unfortunately...so it probably won't be done.
Kinda doubt that the cam/valve cover bolts are on that tight that you can't get them off...agreed they may need replacing, but they should come loose.
Fuel economy is more than likely do to a missfire in number 5. Injector I'm pretty positive is the problem, since the plugs were changed about 30,000 miles ago and we are doing every 50K or so. Coils are good so far. The bolts on the valve cover are pretty rusted out, and I rather not break one off.
Yes, you clearly have other issues that are more concerning. the misfire that has been happening , that recently came to light , which will contribute to the poor MPGs. & if let go long enough will take out the catalytic converters.
There is a laundry list of stuff wrong with the truck, such as the muffler falling apart from the inside (baffles are nearly shot if not already) the sheet metal for the muffler is already breaking from the seem. Though the mileage is getting a bit better about a constant 13.2mpg around town, getting the injector replaced as well as looking into the PCV valve is going to have to be next. I'll credit Ford engineers that its been a pretty reliable engine despite it being such a huge PITA to work on.
Well I just pulled out the PCV valve and it was still rattling. But my dad is going to pick up a new replacement. To his knowledge since we've had the truck for about 200,000 miles or so we have never replace it. Looking at the valve cover closer the top half and the side that faces upwards is caked in oil so maybe its not the valve cover gasket? When the valve is replaced what am I going to look for to make sure that it was for sure that? Just top off the engine with the missing amount of oil and check it every few hundred miles?
If anyone ever needs the part number the one my dad picked up from O'Reilly's its a MicroGard PCV 2322 part# FRAM FV2322
Yes, if the rubber grommet that the PCV sets in isn't sealing and oil coated/crustly it probably would be good to get a new one of those too. If it does't seal you will loose vacuum and that plays into efficiency
But yes , in general, change it (PCV) out and continue to monitor the oil level.
I did not see any grommet at all, might be on the valve cover? New valve did not even come with one either. All it came with was a universal 90* elbow for other vehicles. If it were up to me it would have been a MotorCraft part but only a handful of places around here carry them except for dealers. But so far it seems to be running a bit better. Who'd of thought a small simple piece could make such a huge difference? If I can find a replacement grommet it's going in. I've known Fram filters were crappy compared to other brands and OEM. Even though the quality of those were not there we still ran the filters and never had any issues. I think the first 6 years we owned the truck we used Fram filters (still do for air filters) but since Wally world carries MotorCraft oil filters I run those now.
