easy "slow"power window fix
Received 3,102 Likes
on
do your power windows go down halfway fast, only to come to a stop or almost to a stop and then take forever to go the rest of the way down?
here is a simple, fast, easy fix.
spray a healthy dose of either silicone spray, or penetrating oil down the felt tracks front and rear, and cycle the windows up/down a time or two. by the second or third cycle, they should be lightning fast both up and all the way down.
on
on
yup. the felt runners the window slides in front and rear of the door. i use PB blaster this time, because i ran out of silicone spray. it actually worked better than the silicone, but i don't know how long the PB will last.
i usually do it every 6 months or so, unless i forget and then do it when the windows start to slow down again.
on
