Exhaust
The CATS clean the exhaust gas if several pollutants.
There is an Oxygen sensor in the rear CAT.
The computer compares the response of that sensor with the up-stream front sensor to determine the health and operation of the CATS.
If you remove the CATS, this comparison will fail and a CEL with code will be set permanently. Otherwise the motor should run ok.
The front sensors must remain in place because they controls fuel injection.
Why do you want to remove them if they are working?
There would be no gain in power for truck use.
Good luck.
Good luck.
Are there any codes to support the bad CAT issue? code 420 or 430.
Any other codes?
Has there been any back pressure tests done to prove them as a blockage?
If not, that some one is doing some expensive guessing.
It always pays to give supporting info rather than just ask a question like you first posted.
How does the motor act?
Poor acceleration, poor cold starts, misfire etc.
If you want any possible help, we need to know these things and do not trust the opinions of others as you were 'told'.
Good luck.
Any other codes?
Good luck.
Got the codes P1131 , P0171, P0174
Any other codes?
Good luck.
Any other codes?
Good luck.
I will further investigate for vac leak but I've changed all the hoses and anything that can be changed last time when I was searching for the vac leak which was that stupid little 90 degree on the back of the intake also I hate emission bull**** it's why I buy older trucks and diesels lol
1131 is a bad 02 sensor, the others are both banks running lean. Is your cats are likely fine.
If you remove them, you'll get a code but run fine. However I'd say leave yours in, they should be just fine, and if you do replace I'd use hi flow replacements, not delete them altogether
Graggk
1997 - 2003 F150
09-07-2016 07:04 PM
mauicruza
07-13-2006 11:05 AM
