Reassembled steering column... now truck won't start?
The switch itself looks like this and screws onto the outside of the column:
And there's also a little lever that clips onto the shifter tube in the column to actuate the switch:
The switch itself is adjustable - the mounting holes are slotted so you can line it up properly with P/N for starting (and R for lights), by following the procedure here: https://www.ford-trucks.com/forums/4...ml#post2922591
Or if the little lever fell out of place or broke, they are reproduced - part # 21 here: http://www.lmctruck.com/icatalog/fc/full.aspx?Page=44
I'm actually about to throw mine up on eBay - in the middle of switching to an AOD, which has a transmission-mounted switch that I'm using instead. The switch is pricey, but the lever isn't expensive enough to worry about, so if you broke/lost yours, I could send it for shipping cost. More likely, it just slipped out of adjustment though.
Probably not, but maybe ... depends on how far out of adjustment it is. It's possible that it could be just far enough out that P doesn't work but N does.
If you can wiggle your shifter to a different position and get it to crank (even in R, D, in between gears, etc.), then it's definitely that adjustment. Make sure you've got your foot on the brake if you try that!
mr78F150
03-20-2015 06:39 PM
MUSKRATT2
09-15-2009 07:05 AM
Pwarrenn
09-26-2007 06:01 PM
naggy
07-25-2001 10:34 PM
