Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
need engine swap info...
Old 05-03-2015, 05:08 PM
xlhr8r xlhr8r is offline
xlhr8r is starting off with a positive reputation.
Want to put a 5.0L v8 in place of 4.0L inline 6. Any advise? Thanks...
Old 05-03-2015, 07:38 PM
80ford100 80ford100 is offline
80ford100 is starting off with a positive reputation.
Are you sure its not a 4.9 300 inline 6?
What are you doing the swap in? If it is a Dura spark carbed F100-F250 it is pretty straight forward. First you need to pull the 4.9. Then you need to unbolt the engine perches and bolt in a set of 302 engine perches. You will need a flywheel and starter for the 302 to match your transmission (manual or auto). You will also need a set of 302 engine mounts and the engine wiring harness for the 302. Everything is a bolt in and clip together swap. Use the search function, this topic has been asked a ton by me included when I did my 300 to 351w swap.
Old 05-03-2015, 07:49 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Sometimes you have to drill and grind the perches off the frame. Some of them are riveted on.
You will need a radiator and various other things.
__________________
Dave F
1989 F250 XLT Diesel
Old 05-12-2015, 04:48 AM
ba@cha
Hey, thanks a bunch. I'm working on an '83 f250. Does the 4.9 flywheel fit the 5.0? Sorry I didn't get right back to you, too many irons in the fire.
Do you have any info on removing the smog sys. I recently "fixed"/ it, and performance (esp fuel mileage)went to crap. Now it spits back through the carb, and bucks like mad when I try to accelerate. Can't figure it out. All new ignition. It's a puzzlement. Anyway, thanks again.
Old 05-12-2015, 04:54 AM
I'm getting too old for this...
Thanks for the heads up. I just put 4G in the suspension and misc goodies, and now I can't even drive it. Bummer. Oh well.
Old 05-12-2015, 04:55 AM
David7.3's Avatar
David7.3 David7.3 is offline
confused on a daily basis
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
No the flywheels are different, you need the 5.0 flywheel but it will bolt up to the trans and converter.
__________________
1999 F-350 PSD, 6 inch all spring, 35" Toyo load E tires, 140 gallons of fuel, Detroit true trac front, Detroit locker rear, BDS trans, banks billet converter, banks trans command, TS chip, banks turbo housing, wicked wheel II, FRx Kit w/black spring, Non-EBV Pedestal, diesel site coolant filter, 203 t-stat, IAH delete, 4" turbo back exhaust. 2000 Ford Excursion, bone stock arizona truck, not a spec of rust. 1997 Ford f-350 ambulance, 7.3 IDI 40,000 miles
Old 05-12-2015, 10:49 PM
Thanks. Really want to keep the 6, but just can't figure out what's wrong with it...
Similar Threads
Putting a parts order together kbf1961 6.0L Power Stroke Diesel 14 04-12-2015 08:31 AM
5.0L V8 idle speed raven3 2009 - 2014 F150 11 02-12-2015 04:35 PM
Engine Chirping Noise Diagnosis Tip makuloco2000 Explorer, Sport Trac, Mountaineer & Aviator 0 06-15-2014 04:38 PM
5.0L "High Output" Engine Listed in 1985 Owner's Manual LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-08-2014 09:44 PM
1987-1996 5.0/5.8L intake manifold bolt size question. 5.0stang 1987 - 1996 F150 & Larger F-Series Trucks 3 10-16-2013 11:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
