Homemade stud puller using recycled nails...
Thought you guys might be interested in this. I picked up a junk slide hammer at a flea market.
It set around for awhile until on one of the other forums I saw a guy using something similar. I used a cheap Chinese set of locking pliers, a coupler nut to make the end interchangeable.
I have a ton of nails that I have pulled from my bostich gun, they were actually in a can headed to the scrap yard when I saved them for this.
Anyhow, I hit the low spots for a split second with a mig, and then feed the sharp tip of the nail into the puddle. I then just clamp on and slide the hammer, it actually worked better than I thought it would.
The nice thing about the visegrips is you can make and clamp to other attachments. And fwiw the nails are a one time use unless you sharpen the tips back up. It takes to much heat to stick them when the are blunt.
Rednecks think a like. I've done the same thing with your setup before. I had to pull this flat spot out of the fender but didn't want to just pull the edge out with a slide hammer so I did this and put a ratchet strap on it and tightened it a little at a time to pull the fender out.. whatever works
JEFFFAFA
13
07-12-2017 04:31 PM
F350moneypit
45
02-26-2016 11:47 AM
