Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Sign in using an external account
Register Forgot Password?
1978 - 1996 Big Bronco SPONSORED BY:
lowbeam/high beam 1993 bronco
Old 05-03-2015, 01:58 PM
mudslinging79 mudslinging79 is offline
mudslinging79 is starting off with a positive reputation.
has anyone successfully wired their headlights to where the low beams stay on with the high beams on?
Old 05-04-2015, 09:19 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
why? if your lenses are clean and clear and your running a quality bulb the high beam alone puts out plenty of light. having them adjusted correctly is also a must.
if your experiencing pour light there are a number of things to look at doing. JBG sells a replacement headlight harness that is plug N play and is a nice improvement.
__________________
-- FOR SALE g
94 Bronco XLT 357/E4OD/Warn HS9500I,6"ProComp Stage II 35x12.5x15 BFG AT's,4.88 gears/AussieFront/rear open,Edelbrock efi intake,jba headers
http://www.supermotors.org/registry/...il.php?id=4158
2007 xlt F250 CC 6.0 stock, 33 ToyoMT
2009 Focus
Old 05-04-2015, 01:59 PM
was looking at options other than driving lights. I know the bow tie boys had the option to run both when their trucks have separate bulbs for both low and high.
Old 05-04-2015, 11:29 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
DO NOT attempt this kind of wiring modification! Neither the wiring nor the internal circuit breaker in the headlamp switch are capable of handling the load of all four filaments (two per lamp) at once. Hell, the lamps themselves are not capable of sustaining that kind of operation for more than a few minutes. If you want driving lights, add them and fuse them according to the manufacturer's recommendations. DO NOT wire driving lights into any existing circuit. Again, the wiring/fuse will not be able to handle that additional load.
The other option, is to carry a Class C fire extinguisher in the truck and hope you didn't miss the last insurance premium payment.
__________________
The only stupid question is the one you DON'T ask!
Big Bronco FAQ's
Old 05-05-2015, 01:35 PM
got it. I'll just have to do driving lights, fused, with a relay. debating on switched separate or relayed into a key on circuit
Old 05-07-2015, 04:39 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to behold
Quote:
Single Pole Double Throw switch with center Off.....
Relayed power to use on high beam circuit, Off position, independent operation straight from a fused battery source.
__________________
2013 Ford Taurus Limited 3.5L
2006 Ford Mustang GT 5-speed 3v 4.6L
2002 Ford Explorer XLT 4WD 4.6L V8
rla2005@yahoo.com
Randy A | Central Illinois
Old 05-07-2015, 05:09 PM
power from say battery, relay wired to high beams? High beams on driving lights on, or ....?
Old 05-07-2015, 09:37 PM
ZombieSlayer's Avatar
ZombieSlayer ZombieSlayer is offline
ZombieSlayer is gaining momentum as a positive member of FTE.ZombieSlayer is gaining momentum as a positive member of FTE.
Assuming you're looking at the back of the switch skinny side up (not sideways).
Top = connect to high beam with relay protection (inline relay between switch and high beam circuit)
Middle = off
Bottom = Power to battery (suggest an inline fuse as well) for independent operation (don't need high beams on.)
__________________
Proud owner of a 1995 Bronco XLT, auto trans, 5.8L engine. 95% original.
Old 05-07-2015, 09:46 PM
got it, doubt I'll use a separate switch, as my dumb *** would probably leave it on n come back to a dead battery, lol.
Similar Threads
high beams not working toohott7718 General Automotive Discussion 8 03-03-2015 09:47 PM
dim low beam 2010 escape jnmescape2010 Escape & Escape Hybrid 1 12-23-2014 07:26 AM
Fog Lights + High Beam Mod robinsonpowerstroke 6.7L Power Stroke Diesel 31 08-17-2014 11:36 AM
Flashers don't work, high beams and low beams work texasJ Electrical Systems/Wiring 6 08-09-2014 09:52 PM
High beams...yeah right crazyrwe 2009 - 2014 F150 30 08-26-2013 04:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
