1978 - 1996 Big Bronco
Fuel line retro fit
Old 06-09-2011, 06:49 PM
1sscav's Avatar
1sscav
1sscav is offline
Fuel line retro fit
I have a 93 Bronco that has a frame mounted fuel filter that takes specialty tools to remove. The tool is the same type that is used to remove the fuel lines from the gas tank. My old 89 Bronco used disconnects that utilized a plastic clip that could be removed with a screwdriver.
My question is, can I retro fit my 93 Bronco with 89 Bronco fuel lines (and the filter worm style clamp) with minimum difficulty?
Thanks for any and all help.
Brian
Old 06-09-2011, 07:47 PM
Southern Bronco's Avatar
Southern Bronco
Southern Bronco is offline
Anything is possible,but I don't think its worth the effort when you can get the fuel line release tool fairly cheap.Besides its a real pain to splice the lines.
Old 06-09-2011, 09:51 PM
1sscav's Avatar
1sscav
1sscav is offline
I have the correct tools to remove the filters, but they're not releasing the fittings. And I want to replace the entire fuel line from tank to engine. The factory set up is just too much of a hassle to work with in a reasonable amount of time.
Old 06-10-2011, 12:14 AM
greystreak92's Avatar
greystreak92
greystreak92 is offline
In a word, NO. There is too mug pressure in the system in a 93 from the tank all the way to the rail. The 89 didn't have the full fuel pressure until fuel moved through the frame-mounted high pressure fuel pump. The 93 has the full 40 psi coming from the pump in the tank. The fittings that are on the 93 are necessary with that kind of pressure. If you try to use anything else you will burst connection point and have raw fuel pumping all over the road and undercarriage. There is a good reason it's so difficult to open the fittings. Spray them with penetrating oil an hour before you try removing them.
Old 06-10-2011, 07:38 PM
Southern Bronco
The easiest way I found to remove the fuel lines when they stuck is spray alittle brake cleaner in to flush out any sand/dirt around the line
Old 05-08-2015, 09:51 AM
Brian Ski 44's Avatar
Brian Ski 44
Brian Ski 44 is offline
Originally Posted by greystreak92
In a word, NO. There is too much pressure in the system in a 93 from the tank all the way to the rail. The 89 didn't have the full fuel pressure until fuel moved through the frame-mounted high pressure fuel pump.
I agree... The older system used a few psi 3 or 4. The new system uses at least 10 times that. The rubber hoses are just not rated that high. I think it would work for a while. How long till a line blows off???
BTW you should have the plastic clips. You pry them out with a screwdriver, slide off the line, reinsert the clips(or new ones), then they just snap on. Unless you have the metal ones. Those seem to give me more trouble. More common on the chevys.
GM4WALLS
84
03-18-2017 07:41 PM
khadma
02-05-2017 01:10 PM
brian Felts
04-15-2010 06:45 PM
mick14
02-16-2005 09:13 PM
ChrisWComcast
Aerostar
09-24-2003 01:44 PM
Quick Reply: Fuel line retro fit
