Dana 60 axle with Dana 50 ttb springs (pics)
My newly acquired f250 has the Dana 60 swap done but the Dana 50 springs were reused and also 2 additional springs were added in each spring pack, I drive this truck almost everyday and will also be moving with it(roughly 850 miles) soon. I cannot stand how harsh the ride is..
I'm on a tight budget and cannot do a rsk swap with sd springs or swap Dana 60 springs right now. However I am planning (tomorrow) to remove the extra 2 springs from each front spring pack and hoping it will improve the ride at least a small amount.
So, does anyone know if the ride will improve or could it possibly make it worse??
Included below are some pictures, yes I know a u bolt is missing I removed it so I can take it to the spring shop and get new ones.
F-250 springs are stiffer than F-350 spring even before you add an extra leaf, so swapping to F-350 springs should definitely improve your ride. The spring doesn't deflect as much with the TTB due to the leverage the tire has on it, so the spring needs to be stiffer, even though it would seem to make sense than an F-250 would have a softer spring.
Not sure what I'm going to do now.
I wish. They're definately ttb springs, much thicker than the factory springs that were on my obs 1 tons.
At some point I'll pick up some 1 ton springs from a JY and install new bushings. My front shackles are pretty torn up where they sit up in the frame. I would love to upgrade to sd springs but do not want additional lift from a rsk.
Also for anyone that is wondering, I did lose roughly 2-3" of lift in the front.
95f2504x4
04-15-2012 08:31 AM
christopherrabbitt
19
08-03-2007 05:32 PM
jarch
02-27-2004 11:03 PM
