caliper locked
caliper locked
95 F250 5.8L stick. Front left brake locked front right dragging. Removed FL caliper and tried to push piston back. Wouldn't move. I pulled the pistons and they're fine, no gouging, marring, corrosion or rust. They were full of fluid. I emptied the fluid put pistons back in. They went in easy. Stepped on brake and it filled again and locked. I'm wondering if it's a bad rubber line. Any suggestions to narrow it down?
Thanks.
Thanks.
Received 3,101 Likes
on
easy way to see if it is the rubber hose is apply brakes. then crack loose the bleeder. if fluid shoots out under pressure and the wheel spins again, caliper is good and the rubber hose is collapsed internally, or the master cylinder piston is not returning to center holding the brakes engaged.
That's how I got the caliper to unlock, but I didn't open the bleeder, I opened the bolt on the hose block.
mikeinri
06-29-2015 07:48 AM
AKfordtruck
07-29-2010 01:49 PM
