Leaking diesel on right side of engine near firewall
I noticed a spot under my truck this morning and discovered that it is dripping diesel - several drops a second from what seems like multiple spots. Some of it is all over the sway bar link, other drips are nearby.
What is on that side of the truck/engine that might leak or cause a leak?
I don't know of much back there in a 6.0 except the plug in the head for the fuel. The heads are the same left and right so the one port gets a plug in it. If your talking about a 7.3,6.4 or 6.7 i have no knowledge of those motors at all. Oh wait yes i do the 7.3 has external fuel lines in the valley that rub thru in spots.
Which pipe was leaking? Can't place where this is on the engine:
Well hell. It appears there is a right side fuel line and it is a Royal PITA to replace:
right side fuel line replacement - Diesel Forum - TheDieselStop.com
https://www.ford-trucks.com/forums/1...el-leak-2.html
And a youtube for a 2002 F250 --- looks like a couple hours work for someone who doesn't do it every day..
This could also be a leaky fuel bowl o-ring, much easier and cheaper to fix:
Fuel leak on passenger side - Diesel Forum - TheDieselStop.com
Update on the leak. I used a mirror and saw a little drop of diesel on the bottom of the valve. Zero fuel comes out when I open the yellow valve lever. Decided to pull the entire bowl for a clean & rebuild.
The bottom drain port clogged solid.
Cleaned out the hard stuff then dipped the bowl in my ultrasonic:
Does anyone know the Ford part number for the pressure plugs with the allen wrench ends? One of mine was stripped off and I am going bugger it up taking it off to replace the o-ring. I can't do an online order - need truck this weekend, willing to to by Ford for this part..
Anyone know the ford part number?
Richard Templeton
02-22-2017 08:47 PM
